Shaneshaneukuk Posted February 14, 2009 Share Posted February 14, 2009 Hi, Can I fit a heater blower from a td5 defender into my 200tdi? and is it a easy change? cheers. Shane Quote Link to comment Share on other sites More sharing options...
western Posted February 14, 2009 Share Posted February 14, 2009 if you mean the complete heater assembly that lives under the bonnet, I believe it is slightly taller & has a slightly bigger matrix inside the box. it fits the same as the existing unit. but doubt you will feel any difference. Quote Link to comment Share on other sites More sharing options...
Shaneshaneukuk Posted February 14, 2009 Author Share Posted February 14, 2009 ok many thanks Quote Link to comment Share on other sites More sharing options...
Ian M Posted February 14, 2009 Share Posted February 14, 2009 the connector will be different, but you can just cut it out and solder the wires together. Ian Quote Link to comment Share on other sites More sharing options...
cabell Posted February 14, 2009 Share Posted February 14, 2009 I have done this on my 200tdi. The outlets on my td5 heater exit the top and are oriented straight toward the front of the truck. I used very late 300tdi ROW hoses on my LHD truck and it works great. As mentioned above, you need to change the plug. I also opened up the hole in the bulkhead to match the heater outlet. 40% +/- increase in area = more flow. Quote Link to comment Share on other sites More sharing options...
JST Posted February 15, 2009 Share Posted February 15, 2009 you can but it wont make it any better Quote Link to comment Share on other sites More sharing options...
