Drizz Posted February 25, 2009 Share Posted February 25, 2009 Will 24 spline internals fit in a 10 spline axle casing? Quote Link to comment Share on other sites More sharing options...
Dave W Posted February 25, 2009 Share Posted February 25, 2009 Will 24 spline internals fit in a 10 spline axle casing? Yes... but why would you ? (unless you're changing to upgraded kit) Quote Link to comment Share on other sites More sharing options...
Drizz Posted February 25, 2009 Author Share Posted February 25, 2009 Because we have a set of ten splines in the garage and want to rebuild them off the vehicle, and have the cases powder coated. Saves disabling the vehicle whilst we do it Quote Link to comment Share on other sites More sharing options...
missingsid Posted February 25, 2009 Share Posted February 25, 2009 Because we have a set of ten splines in the garage and want to rebuild them off the vehicle, and have the cases powder coated. Saves disabling the vehicle whilst we do it If you are upgrading to extra strength after market internals then fine, if you keep stock the you are better off buying a complete axle. Have you considered the differences between axle cases? If you upgrade a 10 spline axle to 24 spline you will still be stuck with the older style case. I am not sure what this will affect but certainly LR decided to move from 6 bolt ends to 7 bolt on the later front axle. This was presumably to increase the strength? Marc. Quote Link to comment Share on other sites More sharing options...
Brian S Posted February 25, 2009 Share Posted February 25, 2009 Dan, I know where someone is breaking a couple of 300 Disco's and will have the diffs available cheap. Would it be better to buy these? Quote Link to comment Share on other sites More sharing options...
Drizz Posted February 25, 2009 Author Share Posted February 25, 2009 If you are upgrading to extra strength after market internals then fine, if you keep stock the you are better off buying a complete axle.Have you considered the differences between axle cases? If you upgrade a 10 spline axle to 24 spline you will still be stuck with the older style case. I am not sure what this will affect but certainly LR decided to move from 6 bolt ends to 7 bolt on the later front axle. This was presumably to increase the strength? Marc. I see, Well we will be upgrading the half shafts and diff in the rear axle but keeping front STD Quote Link to comment Share on other sites More sharing options...
Brian S Posted February 25, 2009 Share Posted February 25, 2009 is this for the 110 or the Disco? Quote Link to comment Share on other sites More sharing options...
Drizz Posted February 25, 2009 Author Share Posted February 25, 2009 my 110, johns 90 Quote Link to comment Share on other sites More sharing options...
Brian S Posted February 25, 2009 Share Posted February 25, 2009 I thought John had done his? or is he looking for the front ones? The guy near me will be completly breaking his 2 discos over the next week or so. Quote Link to comment Share on other sites More sharing options...
Drizz Posted February 25, 2009 Author Share Posted February 25, 2009 I thought John had done his? or is he looking for the front ones? The guy near me will be completly breaking his 2 discos over the next week or so. We dont want STD ones, we are uprating diffs and half shafts Quote Link to comment Share on other sites More sharing options...
