West4x4 Posted March 20, 2009 Share Posted March 20, 2009 The hinges oin my td5 and my gf's series 3 have plenty of droop in them and need replacing, main dealer want £13 for one of the earlier type and £28 for the later type. what is the differance and could i be cheap and just replace the pin and not the whole hinge Quote Link to comment Share on other sites More sharing options...
51bigG Posted March 20, 2009 Share Posted March 20, 2009 The hinges oin my td5 and my gf's series 3 have plenty of droop in them and need replacing, main dealer want £13 for one of the earlier type and £28 for the later type. what is the differance and could i be cheap and just replace the pin and not the whole hinge look at page 6, 8th march, topic by Rustynissanprairie about rebuilding hinges would be very easy to do if you have the tools. Graham. Quote Link to comment Share on other sites More sharing options...
crwoody Posted March 20, 2009 Share Posted March 20, 2009 Try this link - http://forums.lr4x4.com/index.php?showtopic=39388 Looks like a very good idea. Quote Link to comment Share on other sites More sharing options...
western Posted March 20, 2009 Share Posted March 20, 2009 difference is the newer hinges have a nylon washer between the hinge sections that the hinge pin passes through. Quote Link to comment Share on other sites More sharing options...
West4x4 Posted March 20, 2009 Author Share Posted March 20, 2009 and that washer means they charge an extra £16!! Quote Link to comment Share on other sites More sharing options...
western Posted March 20, 2009 Share Posted March 20, 2009 and that washer means they charge an extra £16!! don't know about that, probably a different material spec/finish or other changes too. Quote Link to comment Share on other sites More sharing options...
West4x4 Posted March 20, 2009 Author Share Posted March 20, 2009 Hmmm maybe still wanna know if i can just replace the pin that mod looks good but knowing me i'll balls it up somehow Quote Link to comment Share on other sites More sharing options...
western Posted March 20, 2009 Share Posted March 20, 2009 the hinge pins are not listed as seperate parts, might be possible to use a Mills or roll pin to replace the original, or drill out the hinge parts & have some new larger diameter pins made. Quote Link to comment Share on other sites More sharing options...
Cat_J Posted March 20, 2009 Share Posted March 20, 2009 You can knock the pins out with a hammer and something strong then just stick some washers in there Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted March 21, 2009 Share Posted March 21, 2009 You can knock the pins out with a hammer and something strong then just stick some washers in there There isnt enough 'gap' between the two hinge halves to slip any kind of long lasting washer into without having to machine away any material. The newer TD5 style hinges are also thicker and require new bolts-I have stainless ones holding mine on hence why I did my modifications (which seems okay so far-the 110 is my daily driver) as I didnt want the expense of new hinges plus new stainless bolts. The standard hinge pin has splines to hold it in place, they are not available seperately and the hinge body itself wears also, you might as well try my method-its takes less than 10 minutes per hinge! Or send them to me along with some beer tokens and I'll do them. Quote Link to comment Share on other sites More sharing options...
