Boro Posted March 21, 2009 Share Posted March 21, 2009 Could someone please tell me what the best way of cleaning the inside of the intercooler, inlet manifold and intercooler pipework is please and also the breather pipes that go onto the cyclone breather as i have a replacement cyclone breather and want to clean the pipes out whilst im at it, assume its to leave them soaking in something but what that wont do damage and is aggressive enough to remove the gunge Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted March 21, 2009 Share Posted March 21, 2009 oh my god what a messy job! i cleaned it out with soapy water and a soft nylon bottle brush which worked ok, ive also been told diesel will work and brake cleaner Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted March 21, 2009 Share Posted March 21, 2009 another pic Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 22, 2009 Share Posted March 22, 2009 I use petrol to clean the intercooler. Sloshing it back and forth a few times and using fresh petrol a few times usually gets it all out. Same with the inlet manifold, but you'll never get all of it out because of the shape of the casting. Les. Quote Link to comment Share on other sites More sharing options...
drkwack Posted March 22, 2009 Share Posted March 22, 2009 I did use a weak solution of caustic soda on the metal parts and then sloshed it around making sure I had some good gloves on and saftey glasses in case of splashes, then washed them out with a running hosepipe, dont know if it will work on the pipes though, intercooler is still ok. Quote Link to comment Share on other sites More sharing options...
pathfinder Posted March 22, 2009 Share Posted March 22, 2009 I did use a weak solution of caustic soda on the metal parts and then sloshed it around making sure I had some good gloves on and saftey glasses in case of splashes, then washed them out with a running hosepipe, dont know if it will work on the pipes though, intercooler is still ok. Caustic soda!!!! that eats aluminium, avoid putting that anywhere near any land rover as we all know they are made up of lots of aluminium Quote Link to comment Share on other sites More sharing options...
pinny Posted March 22, 2009 Share Posted March 22, 2009 Caustic soda!!!! that eats aluminium, avoid putting that anywhere near any land rover as we all know they are made up of lots of aluminium i use cellulose thinners gun cleaning grade just make sure there is no fumes before you put it back on Quote Link to comment Share on other sites More sharing options...
