k9unit Posted March 26, 2009 Share Posted March 26, 2009 any body know what size this filler is as mine broke could i use a brass plumbing if so what size blank paul Quote Link to comment Share on other sites More sharing options...
k9unit Posted March 26, 2009 Author Share Posted March 26, 2009 1/2 bsp Quote Link to comment Share on other sites More sharing options...
white90 Posted March 26, 2009 Share Posted March 26, 2009 Swap the rad top one as well whilst there the plastic ones go brittle over time. http://www.x-eng.co.uk/X-Cap.asp Quote Link to comment Share on other sites More sharing options...
teabag Posted March 26, 2009 Share Posted March 26, 2009 £1.40 from B&Q not £9.39 delivered from X-Eng. Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted March 26, 2009 Share Posted March 26, 2009 But don't tighten those excessively or the O ring can squeeze out. The OEM ones have a peripheral groove for it to sit in so it doesn't deform. Quote Link to comment Share on other sites More sharing options...
PaulN Posted March 26, 2009 Share Posted March 26, 2009 But don't tighten those excessively or the O ring can squeeze out. The OEM ones have a peripheral groove for it to sit in so it doesn't deform. What about the B&Q one with some PTFE tape? Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted March 26, 2009 Share Posted March 26, 2009 Probably a 2nd line of defence & it can't hurt. Quote Link to comment Share on other sites More sharing options...
PaulN Posted March 26, 2009 Share Posted March 26, 2009 Probably a 2nd line of defence & it can't hurt. I meant leave the 'O' ring out and use PTFE which seals the thread and acts as a sealing washer? Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted March 26, 2009 Share Posted March 26, 2009 I have left the O ring in but just not flattened it when tightening. It just needs a bit of care is all. The one shown is a parallel thread, so I doubt you could bin the O ring. Quote Link to comment Share on other sites More sharing options...
PaulN Posted March 26, 2009 Share Posted March 26, 2009 I have left the O ring in but just not flattened it when tightening. It just needs a bit of care is all.The one shown is a parallel thread, so I doubt you could bin the O ring. Got it!! Quote Link to comment Share on other sites More sharing options...
teabag Posted March 26, 2009 Share Posted March 26, 2009 I have left the O ring in but just not flattened it when tightening. It just needs a bit of care is all.The one shown is a parallel thread, so I doubt you could bin the O ring. The fat O ring is just to show a sealing possibility. The brass plug is laying in the tool box just in case its ever needed. I have a selection of O rings again from B&Q so may try a thinner one or even a fibre washer when the time comes. But I think replacing my plastic plug will be a long way off, I'm now using the red long life anti-freeze so the plastic plug only has to be removed once every five years, and as the anti-freeze has only been changed three times over the last eleven years the existing plug still looks as new. Quote Link to comment Share on other sites More sharing options...
ahebron Posted March 26, 2009 Share Posted March 26, 2009 The fat O ring is just to show a sealing possibility. The brass plug is laying in the tool box just in case its ever needed. I have a selection of O rings again from B&Q so may try a thinner one or even a fibre washer when the time comes.But I think replacing my plastic plug will be a long way off, I'm now using the red long life anti-freeze so the plastic plug only has to be removed once every five years, and as the anti-freeze has only been changed three times over the last eleven years the existing plug still looks as new. I reckon thats just tempting fate . The one on the engine on my 300tdi cracked whilst being driven, luckily I stopped around the corner from a brass fitting wholesaler. Bugger of a job removing the damaged plastic one. Now both are replaced with proper brass plugs. Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted March 27, 2009 Share Posted March 27, 2009 I thought the reason for replacing them was heat effect, not corrosion. Obviously. I didn't give it a chance to let me down for either reason. Quote Link to comment Share on other sites More sharing options...
tuko Posted March 27, 2009 Share Posted March 27, 2009 I bought 4 alternative brass plugs on eBay that have the O seal groove built in. Basically they are identical to the originals but are a metal not the unreliable plastic. Todd. Quote Link to comment Share on other sites More sharing options...
teabag Posted March 27, 2009 Share Posted March 27, 2009 I bought 4 alternative brass plugs on eBay that have the O seal groove built in. Basically they are identical to the originals but are a metal not the unreliable plastic.Todd. Sounds good. Do you have a link to this ebay seller? Quote Link to comment Share on other sites More sharing options...
tuko Posted March 27, 2009 Share Posted March 27, 2009 Sounds good. Do you have a link to this ebay seller? Here you go: http://cgi.ebay.co.uk/Land-Rover-300-TDi-R...%3A1|240%3A1318 Quote Link to comment Share on other sites More sharing options...
teabag Posted March 27, 2009 Share Posted March 27, 2009 Ok tuko, I have seen that site before. The important part is that groove to retain the O ring, which the brass plug from B&Q or any other plumming materials supplier doesn't have. Quote Link to comment Share on other sites More sharing options...
