Steve 90 Posted March 26, 2009 Share Posted March 26, 2009 Anybody have any ideas for a universal boot that I could use for the transfer box lever?? Ive googled the net and cant find anything that isn't some form of Boy racer "Carbon look" and otherstuff equally as pathetic or a "Classic leather" style which aint really the thing im after. I just want a rubber boot and surround that will fit to a flat surface and will need to be reasonably short for a transfer lever. I must admit I didn't think it would be hard to find as there must be stuff like this used for Kit cars etc all the time but I cant find anything. Any help much appreciated. Steve. Quote Link to comment Share on other sites More sharing options...
nicks90 Posted March 26, 2009 Share Posted March 26, 2009 try the little rubber gearstick boot from a classic mini. thats small in height and footprint. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted March 26, 2009 Share Posted March 26, 2009 early MGB gearlever Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 26, 2009 Share Posted March 26, 2009 Steve , I just cut mine from the Discovery gaiter ,cut a hole and bonded it from under the facia plate . Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 26, 2009 Share Posted March 26, 2009 We used to use steering rack bellows if the hole in the floor wasn't too big. MGB ones are good too. Quote Link to comment Share on other sites More sharing options...
Dave W Posted March 26, 2009 Share Posted March 26, 2009 Try a chandlers, they use a large flexible grommit thing that the control bars go though to an outboard motor. They work perfectly for transfer box levers as they seal around the lever, mount to a flat surface and have 360 degree movement. Typical items... http://www.universalchandlery.co.uk/outboa...ommets-78-c.asp You need to get one a bit larger diameter than you'd expect to make sure you get full movement. Quote Link to comment Share on other sites More sharing options...
yella 90 Posted March 26, 2009 Share Posted March 26, 2009 ive used a witches hat, they are used to finish off holes that have been cut in boats for the cables to come through, cant remember what size hole they are atm, i can check tomorrow when im at work though do a search on goggle it should bring them up dan Quote Link to comment Share on other sites More sharing options...
yella 90 Posted March 26, 2009 Share Posted March 26, 2009 just done a quick search for you steve, heres a link to a place that does them afink ours are only 6-50 though http://www.peterleonardmarine.co.uk/shop/i...products_id=473 if its any good i can send you one down dan Quote Link to comment Share on other sites More sharing options...
