Phil Posted March 30, 2009 Share Posted March 30, 2009 Sorry to be dim but; how do I remove the factory-fitted radio/cassette player from my '02 110? Thanks, Phil. Quote Link to comment Share on other sites More sharing options...
gazelle Posted March 30, 2009 Share Posted March 30, 2009 Quote Link to comment Share on other sites More sharing options...
Phil Posted March 30, 2009 Author Share Posted March 30, 2009 Many thanks for that. Is it necessary to buy the SMD 4091 for this, or is there a more common tool I can use? How does the locking/release mechanism work? Also, the radio in my car doesn't have two holes each side, only one....will the same principle apply? Appreciate any help. Phil. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 30, 2009 Share Posted March 30, 2009 No - you need a 2.5mm allen key for the later VDO radios which is probably what yours is, stick it in each hole and unscrew about 20-30 turns then the radio just pulls out, completely different to older key type radios. Quote Link to comment Share on other sites More sharing options...
Phil Posted March 30, 2009 Author Share Posted March 30, 2009 Ah, excellent, many thanks! Phil. Quote Link to comment Share on other sites More sharing options...
Cat_J Posted March 30, 2009 Share Posted March 30, 2009 I used a hammer... Quote Link to comment Share on other sites More sharing options...
stuck Posted March 30, 2009 Share Posted March 30, 2009 I used a hammer... Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 31, 2009 Share Posted March 31, 2009 I used a hammer... Well that's just rough Quote Link to comment Share on other sites More sharing options...
rallycinq Posted March 31, 2009 Share Posted March 31, 2009 Well that's just rough No, an angle grinder is rough, the hammer just percusive. Cheers David Quote Link to comment Share on other sites More sharing options...
rallycinq Posted March 31, 2009 Share Posted March 31, 2009 The correct answer to the OP's post is:- Park it somewhere dark and the locals will remove it for you free of charge. Cheers SPD Quote Link to comment Share on other sites More sharing options...
Phil Posted March 31, 2009 Author Share Posted March 31, 2009 The correct answer to the OP's post is:-Park it somewhere dark and the locals will remove it for you free of charge. Cheers SPD Happily, not where I live! I'll just have to do it myself... Phil. Quote Link to comment Share on other sites More sharing options...
freeagent Posted March 31, 2009 Share Posted March 31, 2009 come and park it outside my house, the locals nicked mine last month, I'm sure they won't mind taking yours out... Quote Link to comment Share on other sites More sharing options...
