Les Henson Posted April 25, 2009 Share Posted April 25, 2009 The filler/level plug on the swivel housing can sometimes be very difficult to remove. A 13mm spanner usually does it, but if the spanner slips, then vice grips or similar are then needed, which may well ruin the plug. You can use a normal socket to remove it though - just the wrong way round. You need a 15mm 1/2 drive socket and ratchet/T-bar. Put the socket the wrong way round on the plug, then put the square drive of the ratchet/T-bar in the wrong end of the socket. You can then undo the plug in the same fashion as undoing a normal nut/bolt. Les. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 25, 2009 Share Posted April 25, 2009 I went about that a different way Les. Two old sockets. One a 1/2inch drive, the other 3/8inch drive. pressed into each other, then welded....I now have a 1/2inch to 3/8inch female adaptor..... mike Quote Link to comment Share on other sites More sharing options...
GBMUD Posted April 25, 2009 Share Posted April 25, 2009 I am sure I am preaching to the choir, but there are proper tools available for this job too. ...though I also favour improvised methods over spending money unnecessarily. Was that Geoff's Disco? Chris Quote Link to comment Share on other sites More sharing options...
BigMac1 Posted April 25, 2009 Share Posted April 25, 2009 Tis a good tip that. I've also made a socket like Mike, from two old sockets that were worn. Mick. Quote Link to comment Share on other sites More sharing options...
discomikey Posted April 25, 2009 Share Posted April 25, 2009 I went about that a different way Les.Two old sockets. One a 1/2inch drive, the other 3/8inch drive. pressed into each other, then welded....I now have a 1/2inch to 3/8inch female adaptor..... mike my idea was to weld a nut onto a short bolt, then put a socket on each end and use this i the same fashion, then you an still use the sockets if they are not buggered mikey Quote Link to comment Share on other sites More sharing options...
Daan Posted April 25, 2009 Share Posted April 25, 2009 Use a 10 mm socket and a 10 mm allan key on the other side is how I did it. daan Quote Link to comment Share on other sites More sharing options...
