rhydgte Posted May 7, 2009 Share Posted May 7, 2009 For about a year my Discovery has been leaning to the right by a fair amount. It was fitted with +2'' Suspension Kit before I bought it, so I thought a rear spring had sagged, so this week I bit the bullet and bought brand new +2'' Bearmach rear springs and have fitted them today! It still leans/sags exactly the same.... From taking various measurements on both rear sides I can confirm that the driver's side rear sits 2 1/4'' lower than the passenger side. It has new springs fitted so can't be that, could it be a seized trailing arm bush??? Hopefully someone can shed some light!? Cheers Quote Link to comment Share on other sites More sharing options...
thepeawee Posted May 7, 2009 Share Posted May 7, 2009 For about a year my Discovery has been leaning to the right by a fair amount.It was fitted with +2'' Suspension Kit before I bought it, so I thought a rear spring had sagged, so this week I bit the bullet and bought brand new +2'' Bearmach rear springs and have fitted them today! It still leans/sags exactly the same.... From taking various measurements on both rear sides I can confirm that the driver's side rear sits 2 1/4'' lower than the passenger side. It has new springs fitted so can't be that, could it be a seized trailing arm bush??? Hopefully someone can shed some light!? Cheers hello mate i have the same problem but i was thinking it may be the body lift bushes warn on one said i may be wrong does any body know Quote Link to comment Share on other sites More sharing options...
rhydgte Posted May 7, 2009 Author Share Posted May 7, 2009 hello mate i have the same problem but i was thinking it may be the body lift bushes warn on one said i may be wrong does any body know I thought that initially but if you look the rear of the body sits on some rubber stops on the chassis rails (right above the spring turret), so I can't see (on mine anyway) how it can be the body itself 'tipping over' due to worn mount/bush... I might be wrong though! Yes, any ideas?? Quote Link to comment Share on other sites More sharing options...
sheltie50 Posted May 7, 2009 Share Posted May 7, 2009 My old R/R has taken this stance a few times over the years, I always found it to be the front springs, does it look down at the front? Quote Link to comment Share on other sites More sharing options...
pwam2006 Posted May 8, 2009 Share Posted May 8, 2009 For about a year my Discovery has been leaning to the right by a fair amount.It was fitted with +2'' Suspension Kit before I bought it, so I thought a rear spring had sagged, so this week I bit the bullet and bought brand new +2'' Bearmach rear springs and have fitted them today! It still leans/sags exactly the same.... From taking various measurements on both rear sides I can confirm that the driver's side rear sits 2 1/4'' lower than the passenger side. It has new springs fitted so can't be that, could it be a seized trailing arm bush??? Hopefully someone can shed some light!? Cheers Hi there, when I first fitted my 2 inch lift kit to my disco, I found that mine leant over to the drivers side too I found that being the clever clogs I am i'd put the springs the wrong way round. I.e. the springs have a right and left as well as a front and back. So I swapped the coils left for right (as all four were wrong ) and its been straight and level ever since!! I suggest taking the front springs off, and then find level ground and put them next to each other, if one is taller than the other, that is the drivers side spring. Same, though less noticeably, with the back springs. Hope this helps. Apologies if im telling you what you already know! Ryan Quote Link to comment Share on other sites More sharing options...
freeagent Posted May 8, 2009 Share Posted May 8, 2009 Have you measured the ditance between the bumpstop and the flat palte on the top of the axle? My disco sits dead level if you take this measurement, but leans by 25mm if you measure wheel-arches to ground on both sides... Quote Link to comment Share on other sites More sharing options...
karlo Posted May 8, 2009 Share Posted May 8, 2009 Check the rear body mounts. Quote Link to comment Share on other sites More sharing options...
ashtray Posted May 8, 2009 Share Posted May 8, 2009 i know this sounds silly but have you checked your tyre pressures? Quote Link to comment Share on other sites More sharing options...
rhydgte Posted May 8, 2009 Author Share Posted May 8, 2009 Hi there, when I first fitted my 2 inch lift kit to my disco, I found that mine leant over to the drivers side too I found that being the clever clogs I am i'd put the springs the wrong way round. I.e. the springs have a right and left as well as a front and back. So I swapped the coils left for right (as all four were wrong ) and its been straight and level ever since!! I suggest taking the front springs off, and then find level ground and put them next to each other, if one is taller than the other, that is the drivers side spring. Same, though less noticeably, with the back springs. Hope this helps. Apologies if im telling you what you already know!Ryan Cheers for the info I'll have a look tomorrow! Front Springs are also brand new HD items, and all tyres at same psi B) Quote Link to comment Share on other sites More sharing options...
rhydgte Posted May 9, 2009 Author Share Posted May 9, 2009 Can I remove the trailing arm with the wheels on the ground?? Cheers Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 9, 2009 Share Posted May 9, 2009 Can I remove the trailing arm with the wheels on the ground?? Cheers Yes, as long as you are on level ground and preferably with front and rear wheels chocked Quote Link to comment Share on other sites More sharing options...
rhydgte Posted May 10, 2009 Author Share Posted May 10, 2009 Yes, as long as you are on level ground and preferably with front and rear wheels chocked Yes it's on a level concrete drive, excellent, many thanks! Quote Link to comment Share on other sites More sharing options...
