PeteMck Posted May 21, 2009 Share Posted May 21, 2009 Hi i am currently replacing the front turrets on my 90 as the old ones have had it. i already have a 2" lift fitted and was wondering if i fit lowered turrets wot effect they will have? Will they provide greater articulation or just lift the vehicle higher?? Also will i need to start fitting dislocation cones? Cheers Quote Link to comment Share on other sites More sharing options...
bishbosh Posted May 21, 2009 Share Posted May 21, 2009 Firstly, -2" turrets will not affect ride height. They will affect bump travel and depending on the length of your shocks and bump stops may cause the shock to bottom out before the axle hits the bump stop resulting in a destroyed shock. With a 2" lift I would look at raised turrets and longer shocks. Alternatively, replace with standard height turrets. Lowering them is a poor compromise IMHO. Quote Link to comment Share on other sites More sharing options...
scube Posted May 21, 2009 Share Posted May 21, 2009 Hi Doing this is not the best way of getting more travel from longer springs the travel is set by the shock absorbers. I cut two inch’s out of my turrets and fitted drop plates to the rear shocks. I did it because I do a lot of overland travel and it is a lot easer to get standard length shocks if you break one. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 21, 2009 Share Posted May 21, 2009 As stated, lowered turrets make no sense as the compression travel has not been affected by the lift and you may bottom the shock out. The shock is not meant to take these loads. If you put on lowered turret, you should also add longer bump stops to prevent this. Also, the front axle is not limited in articulation travel by the shocks. It is limited by the radius arms. Making changes to the shocks won't influence articulation travel. Quote Link to comment Share on other sites More sharing options...
nicks90 Posted May 22, 2009 Share Posted May 22, 2009 ..... however, if you are running really big tyres and HAVE to fit extended bumpstops to prevent them tearing your inner wings to bits - then yes, they are a sensible way of getting lost axle travel back. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 22, 2009 Share Posted May 22, 2009 True and there are a million other things to take into consideration as well. Quote Link to comment Share on other sites More sharing options...
