moose Posted June 8, 2009 Share Posted June 8, 2009 Hi all, I put a disco engine into a defender and i know that need to change the sender for the temp to read correctly on the dash. I have tried (i think) a NA diesel sender as it has the same thread as the disco but it reads high. So any on have the part number of the sender i need? thanks Paul Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2009 Share Posted June 8, 2009 the Defender temp sender in a 200Tdi is PRC8593 Quote Link to comment Share on other sites More sharing options...
Briarston Posted June 8, 2009 Share Posted June 8, 2009 Hi all,I put a disco engine into a defender and i know that need to change the sender for the temp to read correctly on the dash. I have tried (i think) a NA diesel sender as it has the same thread as the disco but it reads high. So any on have the part number of the sender i need? thanks Paul Don't know a part number, but I used the one from the TD engine which I replaced with a Disco 200tdi. It threaded straight in without any adaptors which some say are (may) be needed. Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2009 Share Posted June 8, 2009 Yep, the 2.5TD sender will fit & work with the original temp gauge. PRC2505 or PRC6663 Quote Link to comment Share on other sites More sharing options...
moose Posted June 9, 2009 Author Share Posted June 9, 2009 Yep, the 2.5TD sender will fit & work with the original temp gauge.PRC2505 or PRC6663 thanks guys Quote Link to comment Share on other sites More sharing options...
poohbear Posted June 9, 2009 Share Posted June 9, 2009 Hi, I tried my original TD sender when I converted to the Tdi - I found it read high and so have fitted the sender that Steve Parker supplies. HTH. Dave. Quote Link to comment Share on other sites More sharing options...
