renault4 Posted June 8, 2009 Share Posted June 8, 2009 further to my previous post about my battery discharging overnight,I have narrowed it down to the alternator. with the positive lead off the battery I connected a meter between the possitive lead and the possitive post on the battery and I had a leak of over 3amps after a sugestion by a forum member, I un plugged the three pin plug on the back of the alternator and put the meter back on. no leak. plugged the alternator back in and leak is back. OK so what do you think could be the problem and what do you think I should change? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 8, 2009 Share Posted June 8, 2009 Probably a dodgy diode pack which is leaking current the wrong way. Your option is either: 1. New diode pack for £10 (ish?), disassemble alternator and solder it in 2. New alternator from the scrappy (mine cost £23.50) Personally I think 2 is the better option, but it's up to you. You could always do 2 and then 1 and then you have a spare Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2009 Share Posted June 8, 2009 Fix or replace is the only way to cure the problem Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 8, 2009 Share Posted June 8, 2009 1. New diode pack for £10 (ish?), disassemble alternator and solder it in Reconditioning a magneti marelli A127 Alternator Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 8, 2009 Share Posted June 8, 2009 I would just go buy a recon alternator. The rebuild kits dont replace the large coils inside the alternator (Stators?) and on mine, i spend bloody ages rebuilding it, soldering in the new diode pack and regulators, and found i'd build myself a nice arc welder when i tried to connect it back to the battery, the stator was shorting out as all the insulation had begun peeling off and presumably me cleaning it up finished it off. Quote Link to comment Share on other sites More sharing options...
