02jcole Posted June 9, 2009 Share Posted June 9, 2009 Can anyone suggest a supplier where I can purchase a 52mm VDO rev counter for my 300tdi defender, someone suggested a company called low tension? I know of croytec, but their prices seem really expensive James Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 9, 2009 Share Posted June 9, 2009 http://www.merlinmotorsport.co.uk/p6175/VD...oduct_info.html Edit: Corrected the link Quote Link to comment Share on other sites More sharing options...
Gavin Hatton Posted June 9, 2009 Share Posted June 9, 2009 What about a rev counter that doesn't go to 8000rpm, some how I think that amount of revs is a little optimistic for my 200tdi? I've found a Durite one, are they any good? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=310120782664 Quote Link to comment Share on other sites More sharing options...
western Posted June 9, 2009 Share Posted June 9, 2009 Try Europa Spares VDO Vision rev counter 52mm & 80mm you need the 52mm version. Vdo actually make the 52mm rev counter that was fitted to V8 50th 90's [my rev counter is one of those] the link above gives 0 to 6000rpm which is fine for a Tdi Quote Link to comment Share on other sites More sharing options...
boy Posted June 10, 2009 Share Posted June 10, 2009 can u just buy any after market rev counter !!! Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted June 10, 2009 Share Posted June 10, 2009 No. You need a rev counter that will work with the waveform from the W terminal on the alternator, as apposed to the ignition/coil firing events used for a standard petrol rev counter. Quote Link to comment Share on other sites More sharing options...
boy Posted June 10, 2009 Share Posted June 10, 2009 o thats why the one i have don't work then !!! many thanks Quote Link to comment Share on other sites More sharing options...
