Briarston Posted June 11, 2009 Share Posted June 11, 2009 I've got a Disco trans.box to fit to my 90. I had to remove the front drive flange to replace the prop. bolts. It seems to be stuck in difflock. The selector arm moves and the detents can be felt. Sometimes it seems to free, but when rotating the gears I can hear clicking, and then it locks again. When I got the box it seemed all ok. It has been lying about for a while, inside. Do you think its just got dry and sticky, or have I upset something removing and replacing the drive flange? Any advice would be gratefully received! Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 11, 2009 Share Posted June 11, 2009 I've got a Disco trans.box to fit to my 90. I had to remove the front drive flange toreplace the prop. bolts. It seems to be stuck in difflock. The selector arm moves and the detents can be felt. Sometimes it seems to free, but when rotating the gears I can hear clicking, and then it locks again. When I got the box it seemed all ok. It has been lying about for a while, inside. Do you think its just got dry and sticky, or have I upset something removing and replacing the drive flange? Any advice would be gratefully received! When you use the difflock, i often find i need to run it in reverse a short distance to disengage it. I'd connect it back up and try this. Quote Link to comment Share on other sites More sharing options...
Briarston Posted June 11, 2009 Author Share Posted June 11, 2009 When you use the difflock, i often find i need to run it in reverse a short distance to disengage it. I'd connect it back up and try this. Thanks for the response, but the box is not fitted yet. As far as possible, I wanted to make sure it was ok first. Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2009 Share Posted June 11, 2009 as most Discovery vehicle rarely get used in difflock it's most likely partly siezed, operating it while rotating the transfer box gears should hopefully get it working again. Quote Link to comment Share on other sites More sharing options...
Briarston Posted June 12, 2009 Author Share Posted June 12, 2009 as most Discovery vehicle rarely get used in difflock it's most likely partly siezed, operating it while rotating the transfer box gears should hopefully get it working again. Thanks. Removed the side plate today. The diff. lock is working correctly. Seems its a problem with the centre diff. Feels as though there is something amiss with the planet gears, sometimes it will spin and then jam, as though something has got in the teeth, locking the diff. that way. Is it worth investigating further, or should I start looking for another t/box? Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted June 12, 2009 Share Posted June 12, 2009 As it is currently faulty you have nothing to loose by pulling it apart. Quote Link to comment Share on other sites More sharing options...
