rich90 Posted June 14, 2009 Share Posted June 14, 2009 Hi I've noticed that my rear propshaft has come loose from the transmission brake drum. When I tried to tighten the nuts, the bolts keep spinning and I can't remove the nuts. Grrr... Is there a simple way to remove them? Are the propshaft bolts held by splines on the flange? Quote Link to comment Share on other sites More sharing options...
western Posted June 14, 2009 Share Posted June 14, 2009 The bolts are normal hex head & one flat sits against the prop flange centre to stop the bolt turning Quote Link to comment Share on other sites More sharing options...
landmannnn Posted June 14, 2009 Share Posted June 14, 2009 Sounds like someone has used the wrong nuts and bolts. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted June 14, 2009 Share Posted June 14, 2009 Mine spun for real . Got me swearing like mad and in the end I destroyed the thread. Ordered 8x from Lrseries.. FRC3602 for rear and BT606101L for front. Does cost a fortune Quote Link to comment Share on other sites More sharing options...
dantd5 Posted June 14, 2009 Share Posted June 14, 2009 DOH .... Ralph I think I was a little faster this time with Part nr...... Quote Link to comment Share on other sites More sharing options...
western Posted June 14, 2009 Share Posted June 14, 2009 DOH .... Ralph I think I was a little faster this time with Part nr...... but there's no request for a part number Quote Link to comment Share on other sites More sharing options...
dantd5 Posted June 14, 2009 Share Posted June 14, 2009 but there's no request for a part number Oh sure there was a request.......Bump... B) Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 14, 2009 Share Posted June 14, 2009 if you can get the nuts off (by cuting or other method) there's a single nut that retains the drive flange. Be prepared for some oil leakage when you remove the flange. There's a large circlip that retains the bolts to the flange. Just get replacement 8.8 bolts and locnuts from your local fastner shop. I think they are 3/8 BNC. Quote Link to comment Share on other sites More sharing options...
ciderman Posted June 15, 2009 Share Posted June 15, 2009 if you can get the nuts off (by cuting or other method) there's a single nut that retains the drive flange. Be prepared for some oil leakage when you remove the flange.There's a large circlip that retains the bolts to the flange. Just get replacement 8.8 bolts and locnuts from your local fastner shop. I think they are 3/8 BNC. Nearly , 3/8 UNF Quote Link to comment Share on other sites More sharing options...
