crxxx Posted June 15, 2009 Share Posted June 15, 2009 well found my gear box leak... click to enlarge top seal one the gear box. anyone got a how to on how to replace the seal?? Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted June 15, 2009 Share Posted June 15, 2009 IIRC, there is just a gasket between the housing on the top and the extension housing that it is mounted to. Either replace the gasket or use instant gasket / RTV. Quote Link to comment Share on other sites More sharing options...
crxxx Posted June 15, 2009 Author Share Posted June 15, 2009 yeah i just wondered whats behind the plates etc before i start to take things appart Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 16, 2009 Share Posted June 16, 2009 Yep, there is a gasket there. It's straight forward to remove the selector housing from the gearbox. You may have to lower the gearbox or lift the seatbox to get at the 2 rear bolts. There's a selector yoke in the gearbox that the gear lever engages with. Just don't move it too far left or right or the reverse lever can disengage within the box. Quote Link to comment Share on other sites More sharing options...
crxxx Posted June 16, 2009 Author Share Posted June 16, 2009 thanks fot the heads up, i just reading a pdf which had the reverse plunger on it and that seems to show the assemble Quote Link to comment Share on other sites More sharing options...
tedsmart Posted June 22, 2009 Share Posted June 22, 2009 thanks fot the heads up, i just reading a pdf which had the reverse plunger on it and that seems to show the assemble Not wishing to hijack your stuff!! Just wondered where you got that PDF as my gearbox leaks from the top as well!! Cheers ted Quote Link to comment Share on other sites More sharing options...
dantd5 Posted June 22, 2009 Share Posted June 22, 2009 Me too.... Need that PDF... Kindly forward contents mate..... B) Quote Link to comment Share on other sites More sharing options...
crxxx Posted June 26, 2009 Author Share Posted June 26, 2009 ill pop a copy of the oage on my server for you later and send you link Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 26, 2009 Share Posted June 26, 2009 Me too.... Need that PDF... Kindly forward contents mate..... B) have a look here Gearbox is workshop manual 3 Quote Link to comment Share on other sites More sharing options...
Read Posted July 1, 2009 Share Posted July 1, 2009 have a look hereGearbox is workshop manual 3 Excellent work ! Many thanks Quote Link to comment Share on other sites More sharing options...
