TDi misfire
Hhmmm, :( i'd hope they would have lasted more than 3000 miles :angry: I guess i could get them checked by the people who referbed them.
If they have only been on for 3000miles then there's a fair chance that thats it. Before replacing then you could try some redex but realistically you probably got a tiny bit of carp in the pipe when you last changed em.
Any ideas on what would cause a 200 to sudenly start to misfire at idle and lower revs ?
So far i've only checked the injector pipes and returns as i thought they may have worked loose since fitting new injectors a few weeks ago.
did you fit new injectors cause you had previous running problems? .......if youdidnt..."if it aint broke dont fix it "!!!
