Exmoor Beast Posted July 18, 2009 Share Posted July 18, 2009 What a pig of a morning. Just had a right fiasco getting the 110s handbrake apart, theres a bit of wear on the transfer output flange so the damn bolts are rotating making it a caper and a half getting the propshaft off the handbrake drum. So do I do the sensible thing and replace the flange (Part no anyone?) ot use 4 split washers/locktite or something and try and bodge it? Will Quote Link to comment Share on other sites More sharing options...
western Posted July 18, 2009 Share Posted July 18, 2009 Here you go Will, maybe the big circlip has broken or isn't holding the bolt heads tight enough. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 18, 2009 Share Posted July 18, 2009 It's possible that the original bolts have been replaced at some time in the past with rubbish ones. It's likely that you'll omly need to fit new bolts - just make sure they are the right ones. Les. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted July 18, 2009 Share Posted July 18, 2009 Assuming it is an LT230 (can't imagine it otherwise...) I have a spare flange or two here - used, but known good. Well...the bolts didn't rotate. Yours for a forum donation. Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted July 18, 2009 Share Posted July 18, 2009 will use the back hosuing off the disco Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted July 18, 2009 Author Share Posted July 18, 2009 will use the back hosuing off the disco Now why the devil didn't I think of that! DOH... Will (feeling just a bit daft...) Quote Link to comment Share on other sites More sharing options...
