mudmuncher Posted July 26, 2009 Share Posted July 26, 2009 Hi all My 90 has been lifted +2 inches and the trailing arm bushes are under a lot of stress. I am going to get so cranked arms i just wondered what they actually did ?? Is it just to relive pressure on the bushes or do they correct the diff to axle angles etc Many thanks Chris Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted July 26, 2009 Share Posted July 26, 2009 Using standard length and uncranked trailing arms cause the axle to move forward when a lift kit is fitted becasue the axle pivot in an arc when dropped down. this means that with the lift kit the axle is sitting nearer the front of the vehicle putting more strain on the bushes and joints of the prop. With cranked trailing arms the axle is moved back to its original position and helps to relieve the strain on the bushes and joints as you said. it also helps to improve articulation as there is less strain on the bushes before you start. Hope this helps Tris Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted July 26, 2009 Share Posted July 26, 2009 it relives a lot of stress on the bushes & i have found that they make the bushes last more than one event, personally i use Gwyn lewis rear HD arms which have withstood some heavy abuse Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted July 26, 2009 Share Posted July 26, 2009 correct me if im wrong but i always have thought that cranked trailing arms and camber corection radius arms return the nose of the diff back to horizontal therefore putting more angle and hence strain on the prop. Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted July 26, 2009 Author Share Posted July 26, 2009 I hope not I am fitting them in a hope to sort some of the problems out eg bushes angles etc Quote Link to comment Share on other sites More sharing options...
David_LLAMA4x4 Posted July 26, 2009 Share Posted July 26, 2009 Here is the correction The front arms are to correct the cater angle, they have no effect on camber. The caster angle is the rotation of the kingpin in relation to the vertical which will in a direct way also put the diff back to a more std angel. Having said that the lower plane of the front axle in relation to the chassis means that correcting the caster may well move the prop flanges out of alignment and can cause vibrations On the rear ther is no caster angle so it is purely a releiving of tension on the bushes. Thouigh it will again affect prop flange angles aswell David Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 26, 2009 Share Posted July 26, 2009 Properly made cranked rear arms should return the axle to the right position and the diff nose to the right angle. I would strongly recommend a pair from Jez at HOFS. Gwyn Lewis' kit is also excellent. Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted July 26, 2009 Share Posted July 26, 2009 silly me i meant castor not camber,but i still think on the front end with lifted susp you have a choice dodgy on road stearing or good steering and shorter prop life using castor corrected radius arms. on the rearif the cranked arms are made to incline the nose up towards the trans box all well and good .the bushes def will last longer with corrected arms . Quote Link to comment Share on other sites More sharing options...
