Ian M Posted August 28, 2009 Share Posted August 28, 2009 im looking at buying the above, now ive seen one that bert has, oven shaped, on 3 legs, chimney, door on the side of the oven, swiveling hot plate on the top. not sure where he had it from? can anyone else recommend one? or got one? Ian Quote Link to comment Share on other sites More sharing options...
treebloke Posted August 28, 2009 Share Posted August 28, 2009 Might be a slight logistic problem. http://cgi.ebay.co.uk/AGA-RAYBURN-NOUVELLE-OIL-FIRED-BOILER-COOKER_W0QQitemZ260468904298QQcmdZViewItemQQptZUK_Home_Garden_Kitchen_Ovens_Hobs_Cookers?hash=item3ca528116a After seeing Berts (Oz Pig)I have been thinking about converting a gas bottle. A guy had one at Newark with three sections of straight exhaust for a chimney. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 28, 2009 Share Posted August 28, 2009 You mean like this? Quote Link to comment Share on other sites More sharing options...
hobson Posted August 29, 2009 Share Posted August 29, 2009 Made mine out of a gas bottle, i wanted one 16" in diameter so i can store it in the spare tyre (going to have a spare wheel and tyre and a spare tyre on it's own) used one of the big gas bottles as they are 15 and a half inches in diameter, made removable feet for it out of angle steel too so i can safely have fires without scorching or setting the ground alight. drilled some 10mm holes for ventilation then had a good fire in it to burn the paint off before painting it with high temperature BBQ paint. also made a lid so i can use it as an oven. it works very well, and gives off some good heat. i also found the steel in the gas bottles is loads thicker than the shop bought stuff which is very overpriced (IMHO) one word of warning though to anyone attempting this: make sure the gas bottles are empty, then fill them with water BEFORE grinding or drilling into them, i hear they go with quite a bang if not done properly! Quote Link to comment Share on other sites More sharing options...
twizzle Posted September 13, 2009 Share Posted September 13, 2009 Hi all went to The New Forest show saw the here is the web site www.ozpig.co.uk think it was around 180 pounds Twizzle Quote Link to comment Share on other sites More sharing options...
