gee1599 Posted November 4, 2009 Share Posted November 4, 2009 hi i have just got a defender 90 200tdi im having problems with the diff lock light its not coming on it seams like the diff lock is working but no light (checked and changed bulb) is there a switch in the box that might be faulty or needs adjusting ? what should i check for many thanks graham 1 Quote Link to comment Share on other sites More sharing options...
Orange90-J- Posted November 4, 2009 Share Posted November 4, 2009 hello mate, and welcome to the defender world. its a very typical problem for us all. on my latest defender (200tdi) it stopped working and it was just the wires in the transferbox that had come of... hope this is some help! 1 Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted November 4, 2009 Share Posted November 4, 2009 Check the switch and also the linkage isn't fouling on the sound insulation, like it was on mine! Also make sure you are actually engaging diff lock (jack a wheel up, if its locked you will be able to drive off the jack) Mike Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted November 4, 2009 Share Posted November 4, 2009 i've been told you need to drive 15 meters to get it on sometimes. Also isn't it a pin that goes into something on the diff. Others will know much much more. @Mike...LOL..crack...right on the money,,,, or lack of. Quote Link to comment Share on other sites More sharing options...
lansalot Posted November 4, 2009 Share Posted November 4, 2009 http://picasaweb.google.co.uk/lh/photo/kWZOWop3pLyJsWpeY9-0_g?feat=directlink Linkage slide like the above, the spring-loaded collar slides the cogs together. The light is engaged with a pin that rides up over that linkage. Maybe it's screwed out too far. Check it's actually engaging at all first before worrying about the light. Quote Link to comment Share on other sites More sharing options...
LandyLee Posted November 4, 2009 Share Posted November 4, 2009 I have this exact problem as well , havent looked at it yet but was expecting just the bulb to be gone as my difflock still works just no warning light Quote Link to comment Share on other sites More sharing options...
errol209 Posted November 5, 2009 Share Posted November 5, 2009 I have this exact problem as well , havent looked at it yet but was expecting just the bulb to be gone as my difflock still works just no warning light Another possibility is that the wiring (it goes from top front of bulkhead to transfer box switch along the chassis rail, and has a least one joint in it) has gone brittle, corroded and otherwise ceased to conduct. You can get to most of fairly easily (assuming the floorscrews will come out ) by taking the right hand floor panel out. Quote Link to comment Share on other sites More sharing options...
gee1599 Posted November 5, 2009 Author Share Posted November 5, 2009 Another possibility is that the wiring (it goes from top front of bulkhead to transfer box switch along the chassis rail, and has a least one joint in it) has gone brittle, corroded and otherwise ceased to conduct. You can get to most of fairly easily (assuming the floorscrews will come out ) by taking the right hand floor panel out. spot on the wire for the light was not even pluged in it was tucked up by the bulkhead thanks for all your time and help people Quote Link to comment Share on other sites More sharing options...
LandyLee Posted November 5, 2009 Share Posted November 5, 2009 Another possibility is that the wiring (it goes from top front of bulkhead to transfer box switch along the chassis rail, and has a least one joint in it) has gone brittle, corroded and otherwise ceased to conduct. You can get to most of fairly easily (assuming the floorscrews will come out ) by taking the right hand floor panel out. I`ve already got my floor panels off and your right i just traced wires ,, they were high resistance at gearbox end Quote Link to comment Share on other sites More sharing options...
errol209 Posted November 6, 2009 Share Posted November 6, 2009 I`ve already got my floor panels off and your right i just traced wires ,, they were high resistance at gearbox end HTH and glad you're both sorted. Mine had turned into copper rust for about the last two feet, it just fell apart when I pulled. The reverse light wiring goes this way too eventually, but takes longer. Quote Link to comment Share on other sites More sharing options...
