WEBBY Posted November 18, 2009 Share Posted November 18, 2009 i have a early td5 disco, battery kept going flat after a few days have fitted a NEW battery but i did realise that some electrics still worked even when key is out and removed. wipers, heated seats etc so im guessing this is running down battery. any one else had this issue??? not sure if its related but remote locking does not function either vehicle was parked up for 6 months any good ideas?? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 18, 2009 Share Posted November 18, 2009 yep - most likely water in the fusebox which causes all sorts of issues, be prepared to part with some £££ to somebody with a computer Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted November 18, 2009 Share Posted November 18, 2009 Check your fuse box for water ingress behind it.....water leaks down from the screen seal and shorts out the curcuit board on the back of the fuse box. Quote Link to comment Share on other sites More sharing options...
teabag Posted November 19, 2009 Share Posted November 19, 2009 I don't see why the D2 is any different but the two items you mention are ignition controled on the D1, so you do have a problem somewhere. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 19, 2009 Share Posted November 19, 2009 I don't see why the D2 is any different but the two items you mention are ignition controled on the D1, so you do have a problem somewhere. Well trust those of us with experience that it IS different - the D2 is a much more complicated bit of kit and a lot of the electrics are controlled by the IDM unit built into the back of the fusebox which doesn't exist on a D1. Water gets into the fusebox, rots the electrics and shorts them out, and all sorts of nasty things happen from burning out door locks to the dashboard staying lit up and the engine running when you take the key out (and then the engine stopping when you touch the brake pedal - actual example) to just about any combination of other things. You can pull the fusebox out with a bit of skin and swearing and pop the back cover off, if it's green/brown and smelly in there then a) you need a new one and b) you have a water leak... Quote Link to comment Share on other sites More sharing options...
Wingnut Posted November 19, 2009 Share Posted November 19, 2009 The IDM died on my car - but no water leaks - under the rear cover is as clean as the day it was made. Is the IDM module available seperately,or is there anybody out there who can repair it so it can be kept as a spare? Please excuse the hijack. Peter. Quote Link to comment Share on other sites More sharing options...
teabag Posted November 19, 2009 Share Posted November 19, 2009 Note I was refering to how the items are controlled or are not active until the ign.switch is turned, and I do understand the complexity of the D2. although it's not as complex as my Maserati Quote Link to comment Share on other sites More sharing options...
Wingnut Posted November 21, 2009 Share Posted November 21, 2009 "Is the IDM module available separately,or is there anybody out there who can repair it so it can be kept as a spare" Any information greatly appreciated. Peter. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 21, 2009 Share Posted November 21, 2009 Only replaceable as a unit AFAIK - whole fusebox - 99% of the failures involve water ingress and the whole circuit board is fkd so there's probably not much market for repairing them. Might be worth trying Equicar or similar - I think there are only a couple of different sorts. Quote Link to comment Share on other sites More sharing options...
Wingnut Posted November 21, 2009 Share Posted November 21, 2009 Thanks for the reply Bog Monster, I had to fit a new one to get the car going again. As I said, the fuse box is absolutely spotless inside, no sign of any water ingress, must just be a duff component somewhere internally - way beyond my capability to find it and rectify unfortunately. Peter. Quote Link to comment Share on other sites More sharing options...
