zim Posted November 24, 2009 Share Posted November 24, 2009 Morning, I'm busy checking how to connect my zf auto box up. The current oil system uses both the water radiator and the bottle brush oil cooler along the front. Will i be ok to use something like a mocal 13row x235mm oil cooler instead ? Cheers Gordon Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted November 24, 2009 Share Posted November 24, 2009 (edited) I am currently using one (13row x 235mm) on my 90 300TDI Auto and have had no problems, however it is my daily driver (lots of airflow from forward motion) and doesn't do lots of low speed off road. I would suggest a minimum of a 19row x 235mm with a fan if the vehicle is going to be doing lots of low speed offroad. Pete. editted to add, Although you can over cool a box, it is much harder and less likely to do damage than over heating a box. Pete. Edited November 24, 2009 by Pete Attryde Quote Link to comment Share on other sites More sharing options...
JST Posted November 24, 2009 Share Posted November 24, 2009 i would of thought a 13 row wasnt man enough unless its at the front in the air flow at road speeds (like Petes. whats the truck going to be used for? Dave A does some coolers or certainly has links/recommendations to some Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted November 24, 2009 Share Posted November 24, 2009 The 13row x 235mm gives approximately the same surface area as the standard non bog brush cooler used on the Discovery 300TDI. I will when, funds allow, be increasing the size of mine to 19 row Just to be on the safe side. Pete. Quote Link to comment Share on other sites More sharing options...
zim Posted November 24, 2009 Author Share Posted November 24, 2009 i would of thought a 13 row wasnt man enough unless its at the front in the air flow at road speeds (like Petes. whats the truck going to be used for? Dave A does some coolers or certainly has links/recommendations to some it's going onto my challenge truck. thanks for the replies G Quote Link to comment Share on other sites More sharing options...
russ1 Posted November 24, 2009 Share Posted November 24, 2009 If you didnt think this would cool enough would putting a fan on not benifit this? Russ Quote Link to comment Share on other sites More sharing options...
zim Posted November 24, 2009 Author Share Posted November 24, 2009 A fan will be on it Allisport & mocal do 19 row coolers so might look at them. what do the rest of the challenge trucks do ? as loads run auto's. G Quote Link to comment Share on other sites More sharing options...
Eddie Posted November 25, 2009 Share Posted November 25, 2009 We use quite a large cooler (approx 10" square not sure how many rows) which is mounted behind the truck cab. I've fitted a fan but even with it fitted out of direct airflow I've had to blank of some of the surface area of the cooler because it wasn't even reaching operating temperature. Eddie Quote Link to comment Share on other sites More sharing options...
zim Posted November 25, 2009 Author Share Posted November 25, 2009 We use quite a large cooler (approx 10" square not sure how many rows) which is mounted behind the truck cab. I've fitted a fan but even with it fitted out of direct airflow I've had to blank of some of the surface area of the cooler because it wasn't even reaching operating temperature. Eddie Have you got a temp gauge on it ? What's 'operable' temperature ? cheers G Quote Link to comment Share on other sites More sharing options...
jil6939 Posted November 25, 2009 Share Posted November 25, 2009 I use a Mocal oil/water cooler as it gives you greater packaging options. They are no more or less effective than others and you can cover then in crud. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted November 26, 2009 Share Posted November 26, 2009 I'm using the standard bogbrush cooler without issues. If it was ok for LandRover's powertrain development towing 3 tonnes through the Sahara behind a Discovery, it should be fine behind my Ninety doing some green lanes. I can see the need if you've got a 'ooge V8 putting megawatts into the torque converter for half an hour while the truck's stood on end, but surely for most users it's not the problem it's perceived to be. I have no science to back this up and I don't even monitor the trans temp on mine, but the oil's not burnt so something's working! Quote Link to comment Share on other sites More sharing options...
JST Posted November 26, 2009 Share Posted November 26, 2009 i run a 320mm laminova (water to oil) on an HP24 off a TGV, had some issues initially until the correct bung was fitted in the laminova to restrict the flow and increase the cooling. she now sits at 80deg (it drops a bit on a fast road section in lock up) goes upto about 110 on long climbs on hills etc on road. off road is now fine tops about 90 deg. correct running temp for the box is 80-95deg C i believe, all temps takan at the sump. most of the guys i know running 21 row cooler behind the cab seem to sit at 80deg day in day out Quote Link to comment Share on other sites More sharing options...
general-confusion Posted November 26, 2009 Share Posted November 26, 2009 Same as Jst my box runs at coolant water temp which is 89-93 degrees with no problems Quote Link to comment Share on other sites More sharing options...
Eddie Posted November 27, 2009 Share Posted November 27, 2009 Temperature taken from the sump. www.digi-panel.com/digidevicesweb/trannyoil.htm Quote Link to comment Share on other sites More sharing options...
D3DPE Posted November 27, 2009 Share Posted November 27, 2009 http://www.flickr.com/photos/28213447@N03/3917534094/sizes/l/ I run the Ashcroft Hybrid box in mine with a large oil cooler for mine on the back. It has it's own cooling fan. I used 1/2 inch hydraulic hose to plumb it all. Running a oil temp sensor in the sump and it has never got warmer than about 60 degree's. Works very very well but I think the cooler was aroun £300 +vat. But it is cheaper than killing a box! Dan Quote Link to comment Share on other sites More sharing options...
JST Posted November 27, 2009 Share Posted November 27, 2009 http://www.flickr.com/photos/28213447@N03/3917534094/sizes/l/ I run the Ashcroft Hybrid box in mine with a large oil cooler for mine on the back. It has it's own cooling fan. I used 1/2 inch hydraulic hose to plumb it all. Running a oil temp sensor in the sump and it has never got warmer than about 60 degree's. Works very very well but I think the cooler was aroun £300 +vat. But it is cheaper than killing a box! Dan so she runs a bit cold then. Quote Link to comment Share on other sites More sharing options...
zim Posted November 27, 2009 Author Share Posted November 27, 2009 Good replies thanks Quote Link to comment Share on other sites More sharing options...
D3DPE Posted November 27, 2009 Share Posted November 27, 2009 so she runs a bit cold then. Hi James, Spoke to Dave A about it and he said he was happy with that temp! So, So am I! the box is a fantastic tool and its been fault less! I change the oil and filter pack after every outting and the oil has never smelt or been discoloured! When ya next out James? any news on the next interclub - Can't wait Dan Quote Link to comment Share on other sites More sharing options...
JST Posted November 27, 2009 Share Posted November 27, 2009 well if Dave reckons it ok then i dont think any of us on here can argue with that. replied via email on the other bits. Quote Link to comment Share on other sites More sharing options...
