j55ptk Posted December 17, 2009 Share Posted December 17, 2009 Hello, I have a 1999 P38 4.6HSE. Can I fit my Parrot hands free to this? There seems to be some reports that it doesnt work with the Harmon Kardon head unit. Does anyone have any first hand experience of this? Many thanks in advance, Tim. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 17, 2009 Share Posted December 17, 2009 I would have though it simply comes down to whether the head unit has a phone mute input. I can't see one on the wiring diagrams, but that might just mean that land rover didn't use it - and the ones I have printed are for the earlier system, though I don't think it differs much in that area. It wouldn't stop you using the hands free kit, anyway - as long as you don't mind hitting the power button on the stereo as well as the answer call button Hmm, or does the kit use the car stereo for sound output? As far as I know the standard head unit doesn't have an aux input. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted December 17, 2009 Share Posted December 17, 2009 The Parrot is quite versatile. It sits in line between the head unit and speakers.. Effectively muting the speakers and using them for the phone ! Neil Quote Link to comment Share on other sites More sharing options...
Fatboy Posted December 17, 2009 Share Posted December 17, 2009 My Harmon Kardon head unit didn't have an aux input Geoff. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 17, 2009 Share Posted December 17, 2009 The Parrot is quite versatile. It sits in line between the head unit and speakers.. Effectively muting the speakers and using them for the phone ! Neil In which case there should be no problem using it, though you may have to turn the volume well down as the high line sound system uses a slightly odd level between the head unit and power amps in the doors - it's in between normal speaker outputs and line level. Quote Link to comment Share on other sites More sharing options...
j55ptk Posted December 18, 2009 Author Share Posted December 18, 2009 Thanks for your replies, I will let you know how I get on, when the snow has gone of course. Quote Link to comment Share on other sites More sharing options...
sotal Posted December 18, 2009 Share Posted December 18, 2009 As geoff points out, the speakers are IIRC all amplified, it may be slightly tricky. If it's like the last one I fitted it doesn't need a radio mute etc, it takes the speakers going in one side and then lets the sound come out the other side, if a call comes in it switches over automatically. It's only meant to work with standard speakers and cables though - so not sure how you'll get on - then there is the extra odd bits like the amp and sub for the rear. I bet they'll be on separate cables so how will you mute them? Good luck with it! Let us know how you get on Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 18, 2009 Share Posted December 18, 2009 then there is the extra odd bits like the amp and sub for the rear. I bet they'll be on separate cables so how will you mute them? The sub channel is run through the main connector with the other speaker lines, so as long as the hands free kit at least breaks that channel you should be okay. Quote Link to comment Share on other sites More sharing options...
