bishbosh Posted December 22, 2009 Share Posted December 22, 2009 Can any of you fine folk put your hands on a Bowmotor or Warn XP motor please? I have a little Christmas project on the go and I am keen to know some dimensions: 1. How far does the drive shaft project from the face of the case? 2. What are the major and minor diameters of the splines? 3. How many splines are there (I believe it is 20?) 4. What length of the shaft is splined? 5. Are the splines straight cut or involute? 6. What is the external diameter and width of the shaft support bearing? Thanks very much! Oh, and some pics would be great too...! Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 22, 2009 Share Posted December 22, 2009 You've downloaded an illegal copy of "VapourCAD" for Christmas and you're looking to dimension up a project? I've got a Milemarker motor you can borrow... Quote Link to comment Share on other sites More sharing options...
Orange Posted December 22, 2009 Share Posted December 22, 2009 I've only just seen this Bish and am off out in a few... If no-one has obliged by tomorrow morning then I'll happily take a measuring stick to the garage and wave it around my spare XP for you... Can you just confirm the term 'involute'??? (The oppsite, of course being 'extrolute'.... ) I am guessing that it means angular sides with a flat bottom... but am more than probably wrong... Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 22, 2009 Share Posted December 22, 2009 Bish,,, Have a XP motor here, if you want to borrow it !! About to be rebuild, send the boy in to pick up if needed/of use Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 23, 2009 Author Share Posted December 23, 2009 Thanks guys! Adrian - yes please! Tim - could you bring it to the plain or give it to beardy? I would only need it for a short while to photograph and measure Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 23, 2009 Share Posted December 23, 2009 Tim - could you bring it to the plain or give it to beardy? I would only need it for a short while to photograph and measure Ok, will put with the rest of the relay stuff Quote Link to comment Share on other sites More sharing options...
Ian M Posted December 23, 2009 Share Posted December 23, 2009 I have a bowmotor 1 sat here on my desk! 1: 50mm 2: 16.45mm & 14.3 3: 20 4: 40mm before it tapers in where it goes inside the casing 5: splines are straight but widen as they go down nearer to the shaft 6: external diameter 40mm, inside diameter 16.9mm, depth 12mm Hope this helps Ian Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 23, 2009 Author Share Posted December 23, 2009 Wow! Thanks a lot Ian. Quote Link to comment Share on other sites More sharing options...
Orange Posted December 23, 2009 Share Posted December 23, 2009 1. How far does the drive shaft project from the face of the case? 70mm 2. What are the major and minor diameters of the splines? 16.5mm and 15mm respectively (my calipers aren't the thinnest so they may be a little deeper...) Shaft diameter (unsplined) is 17mm 3. How many splines are there (I believe it is 20?) 20 4. What length of the shaft is splined? 39mm 5. Are the splines straight cut or involute? see comment above...!! 6. What is the external diameter and width of the shaft support bearing? 35.14mm and 11mm respectively (internal diameter 15.33mm) Couple of simple piccies to follow when I get indoors... HTH Adrian Quote Link to comment Share on other sites More sharing options...
Orange Posted December 23, 2009 Share Posted December 23, 2009 Pics as promised... Not entirely sure how helpful they are, but you'll have a real-life one to look at soon by the sounds of it... Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 23, 2009 Author Share Posted December 23, 2009 Thanks a lot Adrian. Most appreciated. Quote Link to comment Share on other sites More sharing options...
