discovery 200 reverse lamps
muddy4x4xfar
hey all my 1993 discovery 200 tdi reverse lamps have stopped working on both sides . iv checked the fuses all seem to be working fine . anybody any idea on what else it could be i wondered if it cold be the reverse switch on the gear box but how would i get to that .
sorry if i seem to be abit of a dummy.
any help would be very much apprieciated.
This is what you will be looking for ↓ on the LH side of the transmission. Follow the wires to see if there is a bad connection or break.
Hi Todd....what manual or CD is that pic from?
Is it a social comment to wish you Happy New Year :)
G'day Todd, G'day Dave. Is that switch one of those that screws in? Could it have unscrewed a tad?
Hi F_F and a Happy New Year....Yes, the switch screws in. I have not seen one loosen up but it is a possibility, I know when you install a new switch, you have to "set it".
If you have a faulty one, try screwing it in a tad further.
Hello landi41 & F_F, Happy New Years ;)
That manual that I was looking through is "Elec. Troubleshooting Manual - LJBEMENR95 (1995)" that I had sitting around in the computer for some time. Yes the switch itself can be the culprit just as well as the wiring to the lights. :unsure: Too bad it wasn't the fuse, it would have been much easier to solve.
Todd.
You have checked the bulbs?
That is an R380 box, the OP has a LT77 box so the reverse light switch is on the top of the box, accessed easiest from under the centre console.
You will probably need a new switch.
