ajh Posted January 11, 2010 Share Posted January 11, 2010 If I am fitting a sedimentor to a 200TDI and have removed the SLU, is there any reason not to install it using the SLU top-bracket mounting location? I have an extended range tank and I am not sure exactly where the "Stock" location for it is but since the draw tube exits forward and the holes are already there (will just make a bracket) seems to be as good a place as any right? On a similiar topic, what should I use for diesel line to bring it from the rear to the front? Is just using 1/4" stainless for the long run and fitting barbs for fitting flex-line to the ends sensible? I really should have bought two of these so I would have another to look at as I re-assemble . Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 11, 2010 Share Posted January 11, 2010 On Military 110s and civvy vehicles fitted with the optional Sedimenter, it's mounted on the outside of the chassis rail on the L/H side. In this position, it catches any water or $h1te in the fuel before it gets too far from the tank. This is also an ideal place to fit something like the CAV D-Wax fuel heater. The factory fit plastic fuel pipes front to rear, I think that these are less susceptible to waxing in low temperatures than metal pipes. Have a look at the Military Parts Books in my signature and the Sedimenter pages in Microcat, they show mountings, pipes, etc... . Quote Link to comment Share on other sites More sharing options...
ajh Posted January 11, 2010 Author Share Posted January 11, 2010 Diesel waxing is only really a problem in the far north of Canada, in November our pumps all switch to winter diesel which I believe is good to -50C. I was planning on fitting a heated filter head eventually though as I will be blending my own fuel starting next year once I pay off the silly expenses on the 110. I will find a way to get the microcat page printed, I tried to buy a license but the rejected my "application" to do so. Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 11, 2010 Share Posted January 11, 2010 sedimentor part number NRC9708 Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2010 Share Posted January 11, 2010 from the 1987 on 110 parts book, fuel system Diesel with Sedimentor fitted Quote Link to comment Share on other sites More sharing options...
ajh Posted January 11, 2010 Author Share Posted January 11, 2010 So yeah, my tank layout is quite different but that gives me a good idea of what to connect where I hope. Still have not gotten any instructions at all for installing the main or aux tanks from SafariEquip, nor the parts that were missing from my shipment. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 16, 2010 Share Posted January 16, 2010 Although it's for a 90, rather than a 110, I thought that you might still find this interesting, as it shows the later type of combined mounting bracket/cover that's used with NRC9708, along with Part No's - Installing fuel sedimentor on Defender 90 He's also written a few other installation articles, here - http://www.rebaseonu.net/go/story Which cover the fitting of the following to his Defender 90 - Aux drive belt: Dayco vs Land Rover branded Dayco Are they really the same? Installing fuel sedimentor on Defender 90 Easy to install using factory parts. Goodridge braided brake hoses Quick review of Goodridge braided brake hoses. Good performance but connectors differ from genuine, giving room for improvement. Safari Snorkel installation fiasco Problems encountered when installing Safari Snorkel model SS-550HF on a LHD vehicle. Mantec swing-away spare wheel carrier installation Overview of the installation process. Polybush Comfort installation Some pictures about a problem I encountered when installing Polybush Comfort (blue) bushes. Allmakes GAL048 steering guard installation Some pictures of Allmakes GAL048 steering guard mounting on Defender 90. . Quote Link to comment Share on other sites More sharing options...
CliveT Posted January 17, 2010 Share Posted January 17, 2010 I see that Safari Equip are still hopeless at getting their orders sent out correctly. It is good kit and they are a nice bunch of people and very helpful, but I've had so many problems getting the correct parts made/sent out. They really need to sort out their order processing/dispatch issues. Quote Link to comment Share on other sites More sharing options...
