Aragorn Posted January 22, 2010 Share Posted January 22, 2010 So i've got myself a Disco2 transfer box for the defender, was looking at it last night, taking off all the disco cable gubbins and seeing what i needed to change to make it fit the defender. I noticed a lot of oil around it so decided to investigate. Seems the handbrake drum is full of oil, so presumably the rear prop oil seal is needing changed? The "sump" pan is also very oilywet, so i guess it would be a good idea to reseal that too. I also need to change the front prop flange for a Defender one so i'll do the front seal at the same time. My query is about the front housing. As you can see there is black "goo" all over that side of the housing, and i'm wondering where its coming from. The other side is dry, the only gooey bit is whats in the photo... Is it likely to be the joint between the front housing and the main casing, or perhaps the hi-lo turret? Any ideas would be much appreciated! Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted January 22, 2010 Share Posted January 22, 2010 The O ring seal fails on the end of the intermediate shaft ........... you can just see it in the picture. In very bad cases the housing wears slightly oval ................... Quote Link to comment Share on other sites More sharing options...
white90 Posted January 22, 2010 Share Posted January 22, 2010 this seal leaks Quote Link to comment Share on other sites More sharing options...
Aragorn Posted January 22, 2010 Author Share Posted January 22, 2010 I see! That was an easy answer! What kinda job is it to change the seal? Megastripdown or a quick swap out? I hope the box isnt knackered! Was supposed to be from a "low mileage" V8 Auto Disco2... Cheers Kev Quote Link to comment Share on other sites More sharing options...
white90 Posted January 22, 2010 Share Posted January 22, 2010 Big strip down there is a crushable spacer on the shaft. if the hole is ovaled the box will be US Quote Link to comment Share on other sites More sharing options...
Aragorn Posted January 22, 2010 Author Share Posted January 22, 2010 Heh thats typical. Presumably i wont be able to tell if the hole is ovalled until i strip it down either? Is the stripdown/rebuild something that can be done with a normal set of garage tools, or does it require various special pullers/widgets/etc? I thaught these LT230's were supposed to be the only part of the transmission that landrover did right! Quote Link to comment Share on other sites More sharing options...
white90 Posted January 22, 2010 Share Posted January 22, 2010 Or do what I did Clean the area meticulously and cover it in RTV Sealant No oil leaks since. Strip down I couldn't but it isn't rocket science. on Ashcroft replacement boxes I see a smear of RTV here also http://217.34.53.228:9876/uploads/230a.jpg Quote Link to comment Share on other sites More sharing options...
ashtrans Posted January 22, 2010 Share Posted January 22, 2010 Hi, we fit an oversize O ring and silicon for good measure on all rebuilds although if they have worn too far they go on a rework pile to be clocked up, overbored and sleeved, Quote Link to comment Share on other sites More sharing options...
martinspragg Posted January 23, 2010 Share Posted January 23, 2010 Th rebuild of a transfer case is much easier than for the transmission. There are a few special tools required but you can get around them or borrow a dial guage to get it set up correct. I am in process of rebuilding a spare and my temporary hold up is the need of a set of shims (not available here) otherwise I would have completed the job in a few days. The intermediate shaft is a small design flaw because it leaks when worn and the only way to get to it is by dropping the transfer case. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted January 23, 2010 Author Share Posted January 23, 2010 Cheers for that. I think i'll go with the clean and RTV approach for now. Presumably it's not going to self-destruct, so i'll use it as is, and can perhaps look at a rebuilt replacement at some point in the future should it get worse. I suspect the R380 is going to be the component i'll have trouble with, i cant see the high mileage TDi box i have lasting too long with 400nm running thru it! Kev Quote Link to comment Share on other sites More sharing options...
white90 Posted January 24, 2010 Share Posted January 24, 2010 Mine has lasted years so far the level in the box barely changes a small leak goes a long way it seems. Quote Link to comment Share on other sites More sharing options...
