dwappat Posted February 19, 2010 Share Posted February 19, 2010 Hi everyone, The bushes on the front Radius arms from my 1984 LR90 are very worn and need replacing. Instead of trying to struggle with removing the arms and then trying to fit the new urethane bushes to these,(all the while the truck is jacked up and not roadworthy) I had and ingenous thought (so I thought!!!!) of picking up a spare set of arms from a Range Rover Classic as I figure they are the same narrow gauge at the front. Have I been too hasty and acquired radius arms that wont fit my 90? Quote Link to comment Share on other sites More sharing options...
jad Posted February 19, 2010 Share Posted February 19, 2010 depends on the width of the radius arms at the axle end. range rover ones may well be wider by about 10mm Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 19, 2010 Share Posted February 19, 2010 Also make sure they are not the early imperial ones, they chassis end is smaller on the imperial ones. Quote Link to comment Share on other sites More sharing options...
dwappat Posted February 19, 2010 Author Share Posted February 19, 2010 Also make sure they are not the early imperial ones, they chassis end is smaller on the imperial ones. I believe that they are both the narrow bushed ones, but as you said, they might be the small circumference body mount type at the rear. Am I able to buy the matching rear bushes for a Range rover and fit them to my 90? Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 19, 2010 Share Posted February 19, 2010 The mounts on the chassis are different too, the holes are smaller for the imperial arms. A mate with an very early RRC had to change the mounts on the chassis to fit the later metric raduis arms. Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted February 19, 2010 Share Posted February 19, 2010 I have a 82 90 & have some castor correction arms off my old 89 Disco, anyone know if these are the same Thanks in advance John Quote Link to comment Share on other sites More sharing options...
