heath robinson Posted February 22, 2010 Share Posted February 22, 2010 Hi. I've been considering spring isolators, and reading the threads on here. I've found the RBC100111 which looks like this - What I'd like to know is this. Does anyone make this without the relocation cone bit? I've got Gwyn Lewis challenge turrets, so a rubber bit on a turret ring would be the only way I can see of having spring isolators without loosing them every time the spring dislocates. For the back springs, I can see a way of making isolators out of rubber to fit around the challenge re-locator. Any thoughts anyone? Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted February 22, 2010 Share Posted February 22, 2010 Discovery 1 and range rover ones look like this :- Click Here Part number :- ANR 2938 Pete Quote Link to comment Share on other sites More sharing options...
western Posted February 22, 2010 Share Posted February 22, 2010 IIRC Discovery or RR isolator rings can be used on the front of a 110, no good on the rear as the springs are a larger diameter. found this one RNF100090D but can't find a photo of it. Quote Link to comment Share on other sites More sharing options...
cieranc Posted February 22, 2010 Share Posted February 22, 2010 Correct as always , I have Disco rings on the front of my 110. Can't say I noticed much difference mind. Rear springs are 1" larger diameter, so Disco one's won't fit. Quote Link to comment Share on other sites More sharing options...
heath robinson Posted February 22, 2010 Author Share Posted February 22, 2010 The standard ones fit, but flail around when you dislocate. I suppose that I could just cable-tie them to the top of the springs. Looking at those ones at Devon, the indents might protect them a bit. IIRC they are about 10mm, aren't they? That's perfect, but I do wonder if the dislocation cones will fit down the middle of them, or get a bit wedged up. Quote Link to comment Share on other sites More sharing options...
heath robinson Posted February 22, 2010 Author Share Posted February 22, 2010 Rimmers do the ANR2938P for £5 a pop, so I'll get a pair to try out. Not the end of the world if they don't cut the mustard, or if the cable-tie-tastic plan fails. Thanks guys, I'll post the results on here when they're eventually used in anger. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 22, 2010 Share Posted February 22, 2010 I used the RBC100111 ones on the front of mine with Gwyn Lewis challenge turrets - they fit ok. Looks like they wouldn't interfere with relocation either... though I haven't got to take off the anti roll bar yet so am not really sure I've really put that to the test. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted March 6, 2015 Share Posted March 6, 2015 I used the RBC100111 ones on the front of mine with Gwyn Lewis challenge turrets - they fit ok. Looks like they wouldn't interfere with relocation either... though I haven't got to take off the anti roll bar yet so am not really sure I've really put that to the test. Bit of a late enquiry but what did you have these on , as i am looking at fitting to front of 110 with a twin shock tubular turret ? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 6, 2015 Share Posted March 6, 2015 Blimey ! Was that 6 years ago They were fitted to these : Quote Link to comment Share on other sites More sharing options...
tacr2man Posted March 6, 2015 Share Posted March 6, 2015 thanks for the quick reply , they should do the job well then Quote Link to comment Share on other sites More sharing options...
