craig Posted February 22, 2010 Share Posted February 22, 2010 hi i have just got an n reg 300tdi disco, when cold it very reluctant to start but will eventually but with lots of smoke and wont rev properly, very slow to rev, once it warm it seems ok but not 100%, i got new glow plugs to fit but cant see that affecting the revs. anyone had this problem? any ideas? cheers craig Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted February 22, 2010 Share Posted February 22, 2010 Hi Craig, What sort of miles has it under its belt? May be worth getting the injectors tested? Ian Quote Link to comment Share on other sites More sharing options...
craig Posted February 22, 2010 Author Share Posted February 22, 2010 130,000 miles, fixed the leaking servo pump today, was gonna do glow plugs tomorrow but gotta work now!!! Quote Link to comment Share on other sites More sharing options...
samd35 Posted February 23, 2010 Share Posted February 23, 2010 I had the same problem with mine in the cold changed the fule filter and it worked fine again! Quote Link to comment Share on other sites More sharing options...
gripper Posted February 23, 2010 Share Posted February 23, 2010 is the cold advance on the injector pump working? Quote Link to comment Share on other sites More sharing options...
ccomley Posted February 24, 2010 Share Posted February 24, 2010 hi i have just got an n reg 300tdi disco, when cold it very reluctant to start but will eventually but with lots of smoke and wont rev properly, very slow to rev, once it warm it seems ok but not 100%, i got new glow plugs to fit but cant see that affecting the revs. anyone had this problem? any ideas? cheers craig Sounds like mine in real cold weather with no pre-heat. Normally at home in winter I use the preheater but on occasions when I've had to rush out at short notice, in temps from +2 to -5, sort of thing, wait for the glows, turn over, it takes several rotations to fire, then it grumbles a bit, doesn't want to rev, and has no pull, as you say, at least until the turbo starts to blow. Once it's warmed up it's good as gold. In the mountains at new year we had -12 indicated and no-where to attach the preheater, I waited for the glows, turned the key and... nothing. Turning over fine but no way it wants to fire. Start over, wait for the glows again, starter... more of the same. This time I feed in a hit of right foot and it eventaully splutters into live. But until it's warmed up, it won't rev over 1000 and won't pull the skin off a pudding. Once warm, again, good as gold. In summer, or when already warm, no sign of similar behaviour, so I just put it down to the lump not being fond of cold mornings. And who would blame it! Quote Link to comment Share on other sites More sharing options...
craig Posted February 24, 2010 Author Share Posted February 24, 2010 thanks for the replies, ill do the glow plugs and fuel filter in the morning, hopefully it will be that simple.... was thinking that it could be the head gasket due to the carp starting and smoke.... Quote Link to comment Share on other sites More sharing options...
craig Posted February 25, 2010 Author Share Posted February 25, 2010 changed glow plugs but it the same. running rough and dont sound right, sounds like it got a miss? is there a way to check injectors? where the best deal on new/ recon injectors? thanks Quote Link to comment Share on other sites More sharing options...
matt bristol Posted February 25, 2010 Share Posted February 25, 2010 to check your injectors, start the engine and one injector at a time loosen the nut that holds the fuel feed so that it allows the fuel to escape - probably require about half a turn max - retightening after. when you find one that doesn't affect the misfire/lumpyness that is your duff injector. If its bosch injectors I have a spare one. Quote Link to comment Share on other sites More sharing options...
sheltie50 Posted February 25, 2010 Share Posted February 25, 2010 Have a look at the air filter and turbo pipes also check that lever from the turbo can move, they have a habit of sticking might be hot so carfull does. Quote Link to comment Share on other sites More sharing options...
boiler man Posted February 26, 2010 Share Posted February 26, 2010 I'm having exactly same with my p-plated 300tdi. sluggish as hell to fire, clouds of pale smoke on fire up, gutless until hot and then not anything to speak of. ive changed lift pump, which was a pig cos injector pipes formed for lr genuine, pattern part different shape and doesnt come with new nuts or 8mm brass olives! (lucky im a plumber!)and blanked off egr with steel plate, but the truck is still carp. waiting to hear your experience and if it gets fixed!! gonna check my fuel sedimenter and filter and turbo sticky lever wotsit thing tomoz. oh yes boyo. isnt it. (im welsh but was kidnapped by the cornish maid army!) Quote Link to comment Share on other sites More sharing options...
craig Posted February 26, 2010 Author Share Posted February 26, 2010 im wondering now if it timing?? was gonna do all the filters etc today but got the hang over from hell........ Quote Link to comment Share on other sites More sharing options...
George1 Posted February 27, 2010 Share Posted February 27, 2010 Guys timing is critical for cold start especially if it is very cold as in the last few weeks in Europe. I can think of a couple of pointers: 1. On EGR valve equipped cars, pump lift must be exactly 1.40mm at TDC (No.1 cyl!) 2. On EGR-blanked off cars pump lift must be 1.54mm at TDC (No1 cyl!) 3. Fuel quality i.e. when last was vehicle filled up, if in summer or autumn, you will have major problems starting it in sub-zero temps. 4. Fuel flow restrictions - Filters! 5. Condition of battery. If it is not fully charged the cranking speed will be reduced and you will struggle to start the motor. 6. There is an adaptor available that fits between diesel filter block and filter with a heating contraption inside. This will preheat the diesel allowing it to flow freely and presto easy starting in winter. Communicate with fellow LR fans in Scandinavia they will be able to give you all the low-downs. Good luck and greetings from South Africa George1 Disco 300Tdi ES Quote Link to comment Share on other sites More sharing options...
