MECCANO Posted February 22, 2010 Share Posted February 22, 2010 Hi Guys I'm trying to establish the standard series ride height for an 88inch. I have the bumpstop to axle casing dims, but i have nothing to compare it to. However i do have under bumper and rear cross memember heights. I thought i had seen these dimensions some where before, but had no luck finding them. Any suggestions welcome... other than refitting the suspension so i can measure it Ta muchly Chris Quote Link to comment Share on other sites More sharing options...
Quagmire Posted February 24, 2010 Share Posted February 24, 2010 Need a tumbleweed smiley... Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 27, 2010 Author Share Posted February 27, 2010 Could someone possibly measure their truck for me, and their tyre size. I will owe you a beer when our paths cross! Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted February 27, 2010 Share Posted February 27, 2010 I will when I'm next with it. I've got standard suspension on mine. Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 27, 2010 Author Share Posted February 27, 2010 I will when I'm next with it. I've got standard suspension on mine. Top man, thank you very much Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted February 27, 2010 Share Posted February 27, 2010 It might be a few weeks though! Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 27, 2010 Author Share Posted February 27, 2010 It might be a few weeks though! Ah don't worry then. I will probably be able to track a local one down quicker. Quote Link to comment Share on other sites More sharing options...
moore101 Posted February 28, 2010 Share Posted February 28, 2010 i'd measure mine but its got 1 ton shackles and homemade leaf seats for the rangie axles, can measure a series 1 if thats any help? (on 205s with ever so slightly sagging leaves, probably only an inch though) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 28, 2010 Share Posted February 28, 2010 I'd offer to measure mine, but... Quote Link to comment Share on other sites More sharing options...
MECCANO Posted March 1, 2010 Author Share Posted March 1, 2010 i'd measure mine but its got 1 ton shackles and homemade leaf seats for the rangie axles, can measure a series 1 if thats any help? (on 205s with ever so slightly sagging leaves, probably only an inch though) Thnaks for the offer, even if fridge is taking the .... I need it to be as standard springs/ and axles. Shackles, i can calculate out easy enough, but i would need to know you axle block hieght. I think a stock series on 6.00x16 is around 450mm up front and 485 at the rear. i presume the swamp limo is atleast double that Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 1, 2010 Share Posted March 1, 2010 I think a stock series on 6.00x16 is around 450mm up front and 485 at the rear. i presume the swamp limo is atleast double that Funnily enough, 450mm is the clearance under the diffs, yes Quote Link to comment Share on other sites More sharing options...
