Series under bumper/ rear cross member hieghts?
MECCANO
Hi Guys
I'm trying to establish the standard series ride height for an 88inch.
I have the bumpstop to axle casing dims, but i have nothing to compare it to. However i do have under bumper and rear cross memember heights.
I thought i had seen these dimensions some where before, but had no luck finding them. Any suggestions welcome... other than refitting the suspension so i can measure it :P
Ta muchly
Chris
i'd measure mine but its got 1 ton shackles and homemade leaf seats for the rangie axles, can measure a series 1 if thats any help? (on 205s with ever so slightly sagging leaves, probably only an inch though)
Thnaks for the offer, even if fridge is taking the ....
I need it to be as standard springs/ and axles. Shackles, i can calculate out easy enough, but i would need to know you axle block hieght.
I think a stock series on 6.00x16 is around 450mm up front and 485 at the rear.
i presume the swamp limo is atleast double that :ph34r:
