lapperz Posted February 25, 2010 Share Posted February 25, 2010 hi can i just paint over the rustybits with waxoilwill it do it any good Quote Link to comment Share on other sites More sharing options...
western Posted February 25, 2010 Share Posted February 25, 2010 Scrape off the worst rust, repair if required then cover with chassis black paint & waxoyl underseal over the top. Quote Link to comment Share on other sites More sharing options...
Guest wunntenn Posted February 25, 2010 Share Posted February 25, 2010 This months LROI has an excellent in-depth anti-rust article running over several pages with pictures - sound advice in it. Quote Link to comment Share on other sites More sharing options...
ajh Posted February 25, 2010 Share Posted February 25, 2010 If you can't do localized sand blasting you NEED to wire wheel it and then apply a phosphoric acid rust converter or it will come back, and quickly. Quote Link to comment Share on other sites More sharing options...
lapperz Posted February 25, 2010 Author Share Posted February 25, 2010 ive just wire wheeled over the holes and plated and welded,thats ok isn't it? Quote Link to comment Share on other sites More sharing options...
western Posted February 25, 2010 Share Posted February 25, 2010 with a good coat of anti rust/paint & underseal it'll be fine. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted February 25, 2010 Share Posted February 25, 2010 Personally each time I go off roading, water pours out of the chassis rails. So external coating is only probably 30% effective as the inside will stay wet and rot away much faster. I assume I am right in saying you ideally need one of those complete waxoiling services that can do some internally? Quote Link to comment Share on other sites More sharing options...
lapperz Posted February 25, 2010 Author Share Posted February 25, 2010 i can spray wax oil in shall i do this Quote Link to comment Share on other sites More sharing options...
western Posted February 25, 2010 Share Posted February 25, 2010 Yes, it will all help the chassis last longer. Quote Link to comment Share on other sites More sharing options...
lapperz Posted February 25, 2010 Author Share Posted February 25, 2010 and i just looked it up they want 350 to waxoil my truck when i can do it for fraction, Quote Link to comment Share on other sites More sharing options...
western Posted February 25, 2010 Share Posted February 25, 2010 and i just looked it up they want 350 to waxoil my truck when i can do it for fraction, Whose they ? doing it yourself is the best way to find out about the overall condition & gets you acquainted with the various areas of the chassis. Quote Link to comment Share on other sites More sharing options...
reb78 Posted February 25, 2010 Share Posted February 25, 2010 I have a little welding to do before i continue waxoyling mine - nothing major, a hole behind the gearbox crossmember. Once i have done the outside, i would like to find someone with the correct tools to do the inside, as i'm just not convinced i can do that properly myself. When i changed the rear cross member last summer, the inside of the chassis rails did look in really good condition - what i could see seemed to be mostly covered in paint! Quote Link to comment Share on other sites More sharing options...
lapperz Posted February 25, 2010 Author Share Posted February 25, 2010 Whose they ? doing it yourself is the best way to find out about the overall condition & gets you acquainted with the various areas of the chassis. jus typed it in google and it came up Quote Link to comment Share on other sites More sharing options...
