nightrider Posted March 9, 2010 Share Posted March 9, 2010 I have a 110 csw g-reg with a 300tdi and r380 gearbox in. There is some play on the front propshaft output(can get hold of prop near transfer box and move it up and down) flange on the transfer box which is causeing it to leak a bit of oil. cn this play be adjusted out of this easly any help would be grateful Quote Link to comment Share on other sites More sharing options...
Quagmire Posted March 9, 2010 Share Posted March 9, 2010 I have this too! Anyone? Quote Link to comment Share on other sites More sharing options...
western Posted March 9, 2010 Share Posted March 9, 2010 my front output had some up/down play, I bought a replacement TB from Ashcrofts. didn't have time to mess about trying to fix it as the box had a lot of miles on it, so better off with a new unit. Quote Link to comment Share on other sites More sharing options...
jericho Posted March 9, 2010 Share Posted March 9, 2010 Excessive play in the front output shaft bearings can not be adjusted out,but the bearing should be fairly easy to replace - The shaft is held in by a big circlip,and the bearing pressed onto the shaft. I looked up the figure for acceptable movement in the bearing some time ago,and was supprised by how much Landrover consider acceptable;but I don't have a manual to refer to now. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted March 10, 2010 Share Posted March 10, 2010 Think this is in the tech archive anyway... Quote Link to comment Share on other sites More sharing options...
western Posted March 10, 2010 Share Posted March 10, 2010 Think this is in the tech archive anyway... Correct right here http://forums.lr4x4.com/index.php?showtopic=25053&st=0entry254775 Quote Link to comment Share on other sites More sharing options...
nightrider Posted March 12, 2010 Author Share Posted March 12, 2010 Thanks for the help especialy that link with the photos, does anyone know best place to get bearing and oil seal from and part number of it. many thanks for your help Quote Link to comment Share on other sites More sharing options...
