PITBULL Posted April 5, 2010 Share Posted April 5, 2010 im looking at gettin a chassis to build up but want advice on the best axles stands to use how many to get (do i only need 4 or will i need/do with more) thanks Quote Link to comment Share on other sites More sharing options...
western Posted April 5, 2010 Share Posted April 5, 2010 4 would be ample, don't go below a minimum of 2 tonnes rating as you'll be adding wieght during the build. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 5, 2010 Share Posted April 5, 2010 don't go below a minimum of 2 tonnes rating as you'll be adding wieght during the build If you intend to build an 8-ton truck If you're building a complete vehicle, you only need 1-ton stands. 4 of them on each corner will safeley hold a vehicle weighing 4-tons. If you are repairing a chassis, then bear in mind that if you cut out a lot of rot, then the chassis will deform under it's own weight (I made that mistake once). Les. Quote Link to comment Share on other sites More sharing options...
PITBULL Posted April 5, 2010 Author Share Posted April 5, 2010 thanks for the quick reply any advice on what size would be best Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 5, 2010 Share Posted April 5, 2010 Halfords axle stands are good - I've had them for years. £30 gets you 4 good quality stands. http://www.halfords....cm_vc=IOV4PLPZ1 Les. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted April 5, 2010 Share Posted April 5, 2010 I went for 4 x 3 tonne stands - ratchet type. Obviously over the capacity but the big ones are much wider so more stable. Plenty on ebay. Quote Link to comment Share on other sites More sharing options...
white90 Posted April 5, 2010 Share Posted April 5, 2010 http://cgi.ebay.co.uk/Sealey-axle-stands-3-tonne-6tonne-per-Pair-Ratchet-Type_W0QQitemZ400110065227QQcmdZViewItemQQptZUK_Lifting_Moving_Equipment?hash=item5d286b164b Quote Link to comment Share on other sites More sharing options...
PITBULL Posted April 5, 2010 Author Share Posted April 5, 2010 http://cgi.ebay.co.uk/Sealey-axle-stands-3-tonne-6tonne-per-Pair-Ratchet-Type_W0QQitemZ400110065227QQcmdZViewItemQQptZUK_Lifting_Moving_Equipment?hash=item5d286b164b thanks for that will these be tall enough thought it would be better to have tall ones? Quote Link to comment Share on other sites More sharing options...
white90 Posted April 5, 2010 Share Posted April 5, 2010 They go out to nearly half a metre I'd suggest that will suit Quote Link to comment Share on other sites More sharing options...
PITBULL Posted April 5, 2010 Author Share Posted April 5, 2010 ok thanks Quote Link to comment Share on other sites More sharing options...
