PITBULL Posted April 7, 2010 Share Posted April 7, 2010 im looking at getting a richards chassis and building a 110 200tdi auto my question is if im fitting a auto to a 200tdi what chassis do i get am i right in thinking i will need a 300tdi chassis as the engine sits further forwards then a 200tdi so will be in the right position to fit a auto to a 200 without having to drill more holes in new chassis thanks Quote Link to comment Share on other sites More sharing options...
SiWhite Posted April 7, 2010 Share Posted April 7, 2010 Have all the punctuation keys fallen off your keyboard? I find sentences much easier to read with commas and full stops No idea about your chassis I'm afraid..... Quote Link to comment Share on other sites More sharing options...
heath robinson Posted April 7, 2010 Share Posted April 7, 2010 I'd also try phoning Richards, the guys there are very knowledgeable about this kind of thing. Generally, they've already done it... Quote Link to comment Share on other sites More sharing options...
PITBULL Posted April 7, 2010 Author Share Posted April 7, 2010 phoned richards chassis today not sure the woman i spoke to knew what a land rover was let alone the info i need it was hard enough getting info for a custom chassis after that i couldnt be bothered asking anything else Quote Link to comment Share on other sites More sharing options...
heath robinson Posted April 7, 2010 Share Posted April 7, 2010 Ask to speak to the guy (I'm sure someone on here knows his name) who's in charge of production. He knows many things. Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted April 7, 2010 Share Posted April 7, 2010 unless you have a custom made chassis... i think your going to have to drill holes in a standard 110 200tdi chassis! Quote Link to comment Share on other sites More sharing options...
PITBULL Posted April 7, 2010 Author Share Posted April 7, 2010 i am planing on having a custom chassis made but im sure ive read (on here) that to fit a auto to a 200tdi defender you can move the engine forward to a 300tdi defender position? and a auto will fit on a 300tdi defender without any chassis mods? could be wrong thou Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted April 7, 2010 Share Posted April 7, 2010 I can confirm that an auto will go behind a 300 Tdi without modding the chassis. The engine mounts on a 300 are in a different place to those on a 200 so your 200 engine wont drop straight in to a 300 chassis. There are/were 200 auto Disco's, have a look at one and see if the engine is in the same place as a manual? I would have thought it would be, in which case you wont need a custom chassis. Quote Link to comment Share on other sites More sharing options...
PITBULL Posted April 8, 2010 Author Share Posted April 8, 2010 I can confirm that an auto will go behind a 300 Tdi without modding the chassis. The engine mounts on a 300 are in a different place to those on a 200 so your 200 engine wont drop straight in to a 300 chassis. There are/were 200 auto Disco's, have a look at one and see if the engine is in the same place as a manual? I would have thought it would be, in which case you wont need a custom chassis. thanks for that, but i have read that a 300tdi defender sit further forward due to gearbox being longer (by about 5inches if i remember correctly) so is a LT77 defender gearbox shorter then a r380 which is the same size as a auto? which would make a 200tdi auto fit in a 300tdi chassis? i think i will give them a ring again tomorrow and see if i can speak to the guy Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted April 8, 2010 Share Posted April 8, 2010 Ah yes, you are correct the Defender LT77 is shorter. Would the engine mounting brackets from a 300 Tdi fit on a 200 block I wonder?? Quote Link to comment Share on other sites More sharing options...
T1G UP Posted April 8, 2010 Share Posted April 8, 2010 i'm building a 200 tdi auto, i've got a disco 200 tdi auto as a donor. I'm gonna move the mounts back to get the engine as far back as poss and swap the props round. i thing you can go back 4-5"? the gear selector should then be between the front seats Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 9, 2010 Share Posted April 9, 2010 i'm building a 200 tdi auto, i've got a disco 200 tdi auto as a donor. I'm gonna move the mounts back to get the engine as far back as poss and swap the props round. i thing you can go back 4-5"? The gear selector should then be between the front seats. You can put the gear selector pretty much anywhere within reason as it is on a flexible cable. The hi-lo shifter is however more of a concern as it is fixed to the gearbox. I put my 200 in the 300 position (in a 90) to keep props the same length and avoid a really short rear prop. This does pose its own challenges as the turbo is then very close to the shock turret and you have to find a home for the air filter. However, having said all that, I did it, so anyone can! Oh, and mine is for sale too if you want one ready made! Quote Link to comment Share on other sites More sharing options...
T1G UP Posted April 14, 2010 Share Posted April 14, 2010 Thanks for the offer Bish....got 7" more than you though Quote Link to comment Share on other sites More sharing options...
