Phillis Posted April 27, 2010 Share Posted April 27, 2010 Anyone know how to change 90 door lock barrels? cheers Quote Link to comment Share on other sites More sharing options...
oakesy Posted April 28, 2010 Share Posted April 28, 2010 If it the bust lock type then find a pin hole and use a fine drill or hammer a nail to release the locking pin. Newer types push button there is a screw at the back of the lock. remove door card and look at the levers connecting to the lock and you will see the screw and lever. release that and the lock will loose enough to take out. Quote Link to comment Share on other sites More sharing options...
kingrat Posted April 28, 2010 Share Posted April 28, 2010 On push button handles it can be handy to drill a hole in the steel plate for the window winder mechanism in line with the screw on the back of the lock. This enables better purchase for a screwdriver on the screw. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 28, 2010 Share Posted April 28, 2010 As seen here: http://www.retroanaconda.com/landrover/wp-content/uploads/2009/10/IMG_0662.JPG Small circular hole about half-way up on the left. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 28, 2010 Share Posted April 28, 2010 A stuby screwdrive will just fit, or a hex screwdriver bit and spanner, but failing that, as above, a hole drilled in the right place always a decent screwdriver to be used. Quote Link to comment Share on other sites More sharing options...
