Extra bolt left over from Water Pump housing. Can anyone help?
Can someone please tell me how many bolts secure the water pump, steering pump and belt tensioner housing on a 300 TDI Discovery? I've replaced the "P" Gasket and water pump but I'm left with a 5" bolt and can't see where it's missing from. Just thought I'd ask to save me taking the whole lot apart again. I could've sworn it was from the bottom bracket of the alternator but it won't go through and I've put a smaller bolt through and it seems right.
If not, does anyone know where I'll get a blow up diagram for it?
Many thanks.
Perhaps it's one of the 'spare' ones manufacturers seem to put in things. My camera had dozens of spare screws in it - and I'm sure there are a load more as it rattles when you shake it! :ph34r:
Si
Easy to 'lecture' after the fact I suppose, but it really does pay to make a bolt card. For anyone in the future doing a job like this, it doesn't take long, and saves a ridiculous amount of time when reassembling. More importantly, you know you have all the bolts absolutely correct
See uncle les' pic from removing a timing case...
I did similar out of a piece of 9mm ply for when I do my timing belt changes-being the forgetfull bugger I am it does help me when I need to put it all back together again-especially if the trucks been apart for a few days
John
