Tibout Posted May 11, 2010 Share Posted May 11, 2010 hi anyone know if when you order a propshaft does it comes with both UJ's or do i need to buy them seperately? thanks thierry Quote Link to comment Share on other sites More sharing options...
jbs Posted May 11, 2010 Share Posted May 11, 2010 Normally come complete-with both UJ's ready to bolt on Quote Link to comment Share on other sites More sharing options...
Tibout Posted May 11, 2010 Author Share Posted May 11, 2010 ah ok thanks for that going to order front and rear from paddock change my cv joint last week and now i notice there are some vibration i've inspect both propshaft and there's loads of play on both! i think it will be better to change the whole lot rather than just changing the UJ! if i'm wrong will anyone let me know please thanks thierry Quote Link to comment Share on other sites More sharing options...
gaz489 Posted May 11, 2010 Share Posted May 11, 2010 if there is nothing wrong with the prop id say just change the uj it will work out quite a lot cheaper i think my uj was 20quid fitted at local landy place thats my honest opinion anyway lol Quote Link to comment Share on other sites More sharing options...
kingrat Posted May 11, 2010 Share Posted May 11, 2010 If there is no play on the sliding joint and its not siezed, I would just do the U/J's. Pence to buy in the scheme of things and take less than 30mins per joint. Probably more like 30 mins per prop shaft. Quote Link to comment Share on other sites More sharing options...
Tibout Posted May 12, 2010 Author Share Posted May 12, 2010 is holding the prop in the middle and going back and forward will indicate any play in it? and what do you mean by siezed? the only thing i notice now is that there's loads of play at the UJ's thanks thierry Quote Link to comment Share on other sites More sharing options...
max-ie Posted May 12, 2010 Share Posted May 12, 2010 Hi the prop shaft should slide freely making its overall length greater by a few centimeters. It should not bend at this middle joint at all. If there is any sideways play in the sliding section then it needs replacing. The universal joints are an easy fix and there is a section on here in the tech archive to help you. I would buy gkn or hardy spicer uj's as they are the same ones the main dealer wanted to charge me 50 quid for. I paid 12 quid on paddocks site. Hope this helps max Quote Link to comment Share on other sites More sharing options...
Tibout Posted May 12, 2010 Author Share Posted May 12, 2010 hi thanks very much there's no play in the sliding parts just near the uj's. if i get the upgrade one i guess they will fit no problem.. Quote Link to comment Share on other sites More sharing options...
