NEO Posted May 28, 2010 Share Posted May 28, 2010 I have fitted a 200 tdi engine gearbox and axles on to my series 2a. The only thing lef to do is the speedo i used the disco cable but the speedo reads very low speeds. How can i sort this ? Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted May 28, 2010 Share Posted May 28, 2010 Fit a new speedo drive gear. There's a list of part numbers somewhere, although I doubt there will be one for that ratio. You should be able to get it somewhere close though. Quote Link to comment Share on other sites More sharing options...
Rich_P Posted May 28, 2010 Share Posted May 28, 2010 The speedo head will be calibrated for the standard series transmission and tyre sizes. Quote Link to comment Share on other sites More sharing options...
missingsid Posted May 28, 2010 Share Posted May 28, 2010 One possibility though could be pricey is to see if an electronic gearbox sender is available and fit a programmable speedo. This is what I am considering after years of speedo error in my Series 1. Marc. Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted May 28, 2010 Share Posted May 28, 2010 The speedometer mechanism from a 2 door RRC can be fitted in to the housing for a Series IIA - the route I took when fitting 3.54 diff's to my IIA. The drive gear in the LT230 transfer box would be red if running 205R16 tyres or blue if 235/85R16 or 7.50R16. Cable would be from a 2 door RRC. There is a range of drive gears for the transfer box, so it could be worth checking the speedo accuracy against a GPS before working out which gear is closest. Quote Link to comment Share on other sites More sharing options...
Gremlin Posted May 31, 2010 Share Posted May 31, 2010 put a 90/110 speedo........ G Quote Link to comment Share on other sites More sharing options...
jbs Posted May 31, 2010 Share Posted May 31, 2010 If you have access to a satnav just use that-my tom tom tells me all sorts including the speed of the vehicle I'm in at the time Quote Link to comment Share on other sites More sharing options...
