Jimmy Two-Jacks Posted June 5, 2010 Share Posted June 5, 2010 A little while ago I posted for advice regarding oil leaking from the central section of my rear hub and someone suggested the breather may be blocked…Well have a look at the images the banjo bolt was a solid mass of rust and when I tried to renovate it i crumbled like a biscuit. Question is are these bolts called banjo bolts or is there a proper name for them? Also are they universal to Land Rover axles i.e. not model specific? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted June 5, 2010 Share Posted June 5, 2010 Banjo joints/bolts are a common engineering design. One option is to swap the banjo for a 90 degree push fit pneumatic fitting, which is also very common, and easy to use with industrial pneumatic air line. Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2010 Share Posted June 5, 2010 part number 595478 on page 522 doesn't have a diagram item number so just look in the list below item 1. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 5, 2010 Share Posted June 5, 2010 Bolt - banjo = 595478 Washer - sealing x 2 = 232039 Les. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted June 5, 2010 Author Share Posted June 5, 2010 Thanks Quote Link to comment Share on other sites More sharing options...
