Varsas Posted June 20, 2010 Share Posted June 20, 2010 Hi. Just taken the main bearing cap off my 'new' engine to change the rear crank oil seal as part of general work to do those jobs that are easy to do with the engine out of the car. There is some discolouring on the running face of the end cap, a friend said I should get it checked. You can't really feel the wear but you can see it... I have no idea weather that is worn or not? Does it need replacing? Does it point to a more serious problem with the engine? The rest of it all looks quite clean. Thanks again for any help. Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted June 21, 2010 Share Posted June 21, 2010 Yes it should be replaced, it's the copper showing through the overlay where the crank has worn it as opposed to a discolouration. You can have the crank checked but I doubt it's anything serious. The rear bearing will normally wear faster than the rest as it has the weight of the flywheel pressing on it. Neither an expensive nor difficult task, worth checking your big ends at the same time it's best not to touch the bearing surface though as particles too small to see can get stuck to the bearing by grease which will speed up wear. Cheers, Barney. Quote Link to comment Share on other sites More sharing options...
RobotMan Posted June 21, 2010 Share Posted June 21, 2010 That's worn through to the backing material unfortunately. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 21, 2010 Share Posted June 21, 2010 That's worn through to the copper, so yes it could do with replacing, fortunately they are cheap and of course very easy to do, especially as you have the engine out of the truck at the moment. If that's what the crank bearing looks like, I would change the big end bearings as well, they are cheap, and a 20 min job max on top of what you have already done. Then, as the rest of the engine is in good shape, you shouldn't have to worry about bearing rumble for a good few years Quote Link to comment Share on other sites More sharing options...
Varsas Posted June 21, 2010 Author Share Posted June 21, 2010 Thanks for the advice, I may as well go ahead and change all the main bearings as well as the end cap then, don't want to have to take the engine out again anytime soon... Quote Link to comment Share on other sites More sharing options...
Varsas Posted June 21, 2010 Author Share Posted June 21, 2010 Thanks for the advice. First time doing anything like this! I'll change the whole lot then; they don't seem expensive, that's a main bearing set then I assume. There is some writing on the crank, it says: M-STD B-010 I assume that means it's been machined at some point, and those are the sizes? Does that mean I need standard or 010 oversize main bearings? Quote Link to comment Share on other sites More sharing options...
western Posted June 21, 2010 Share Posted June 21, 2010 Thanks for the advice. First time doing anything like this! I'll change the whole lot then; they don't seem expensive, that's a main bearing set then I assume. There is some writing on the crank, it says: M-STD B-010 I assume that means it's been machined at some point, and those are the sizes? Does that mean I need standard or 010 oversize main bearings? that tells me the crankshafts main bearings are still at standard size & the big end [conecting rod] bearings have been reworked to 010thou of a inch undersize Quote Link to comment Share on other sites More sharing options...
Varsas Posted June 21, 2010 Author Share Posted June 21, 2010 that tells me the crankshafts main bearings are still at standard size & the big end [conecting rod] bearings have been reworked to 010thou of a inch undersize Ah, that makes sense. Thanks. Quote Link to comment Share on other sites More sharing options...
PeterW Posted June 22, 2010 Share Posted June 22, 2010 Ah, that makes sense. Thanks. Dan Wot he sed !!! Saw your PM but only just ! Cheers Peter Quote Link to comment Share on other sites More sharing options...
