RR classic EFI difficult to start....
Smokydiesel
Hi all,
I've got a 1992 classic V8 that is difficult to start.
It always takes about 10 seconds of continues churning before it slowly comes to life.
Got the impression that starting is a bit more difficult when hot than cold.......
In the end I always get it to run, once it's fired up it runs fine.
Battery is full of pep !
Any idea's what could cause this ??
Thanks !
Edwin
  • 3 weeks later...
  • 3 weeks later...
Ignition amplifier.
Hi,
Changed the ECU temp-sensor but without any succes.
Could you please tell me a bit more about this Ingnition Amplifier ?
Where can I locate it, what does it do, easy change ?
Sorry for all the question.....I am a former Diesel-driver so a bit new to the V8-petrol world.. :)
Thanks !!
Edwin
Full technical manuals & fault-finding guide in the technical archive, best just to work through it methodically.
Amp is either on the dizzy or under the coil, but re-reading the symptoms I'd work through the fault book before splashing out on new bits.
