saved
stripy
thanks to all the guys for your advice
just fitted a EGT gauge at full go i was getting just shy of 800c :o
i have now adjusted my bits :D and at full flow its 700c max
thanks again
Well that was a result!
Having an EGT gauge does just that it allows you to monitor easily any adjustments you've done.
good value to save the engine for a smallish outlay.
running large amounts of boost/too much fuelling will of course damage things normally the first to let go is the exhaust manifold, it cracks.
200-300TDIs pretty much the same one just an evolution of the other
200 agricultural runs less boost standard
300 refined but a little more fragile.
Andy at Alisport added to much fuel when I had the intercooler fitted , you get the power increase but fuel consumption dropped to 14mpg
so I adjusted it myself back to more reasonable proportions.
if you really want large boost a hybrid Turbo is the way to go but TDI headgaskets aren't really upto to much extra.
perhaps easier to lose weight from the vehicle than spend lots on tuning products.
