Wheel bearing kits
Maverik
 Share
Hello,
I just purchased 2 Bearmach wheel bearing kits, I was under the impression that they used Timkin bearings, but on inspection of the bearings, all there is, is a few numbers and letters. No "Timkin" in sight. I have a few Timkin swivel bearings that have Timkin stamped all over them, so I'm guessing Bearmach bearings are not Timkin ones, can anyone elaborate?
I can't see Timkin not stamping bearings up with there name if they were from them.
Cheers
Mav
If you ask for OE, they will be timken, but without specifying they will most likley supply the cheapest option - which is not timken.
Bermach certainly supply timken bearings, but you do have to ask for (and therefore pay for) OE quality when you order.
hth
Mark
hth
Mark
This was a boxed "wheel bearing" kit. - so it was pre-made up of components. Not a fan of no name parts, but the bearings don't look to bad. as they're easy enough to change I'll probably fit them up and see how I get on. I've ordered some branded Timkin bearings to keep as spares.
hi there , whats the BM number and I'll find out whats in it for you
cheers
Gary
Same is true of most BM parts, ask for OEM every time :)
 Share
