Exmoor Beast Posted August 2, 2010 Share Posted August 2, 2010 my 110s gearbox has been a bit tired for some time now and this weekend the transfer box seems to have 'let go', I seem to have mislaid low range So I'm pondering what to do next. 1. Sell my kids and buy and new ashcroft gearbox/transfer box and have done it with. 2. Rebuild mine or buy some salvage ones and rebuild them and do a swap (me and a mate did our Discovery one a few years ago and it worked out at less than £100 to do all the R380 bearings/seals etc. 3. Buy an R380 and rebuild it as opposed to the LT77 I have now. 4. Something else (anyone mentioning Auto boxes will be shot). Whats the lowest 1st gear option available as standard? Will Quote Link to comment Share on other sites More sharing options...
Aragorn Posted August 2, 2010 Share Posted August 2, 2010 I wouldnt want to waste any money on an LT77. Unfortunately, having said that, using a stock R380 puts the engine in a completely different place, so you need to either spend a lot of money buying a stubby R380, or spend a lot of time/money/effort moving the engine. Gear Ratios are here: http://www.expeditionlandrover.info/gear_ratio.htm Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted August 2, 2010 Author Share Posted August 2, 2010 I wouldnt want to waste any money on an LT77. Why do you say that? I've caned the backside out of mine for the past ten years and its still functioning, reverse takes some persuation at times, but its done well I think. Will Quote Link to comment Share on other sites More sharing options...
Aragorn Posted August 2, 2010 Share Posted August 2, 2010 Because the R380 improved upon it in lots of ways, and for the money you'd spend rebuilding a LT77 i'd rather spend it on an R380. Given the second point though, its a more tricky choice. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 2, 2010 Share Posted August 2, 2010 I've caned the backside out of mine for the past ten years and its still functioning, reverse takes some persuation at times, but its done well I think. Will I agree - my last one lasted 20years. The later LT77 (suffix G onwards i think) are reputedly as strong as the R380. I beleive they both handle similar max torques (around 380nm...). Having said that the gear changes are supposed to be nicer on the R380 and you have the option to easily add an oil cooler if you require it. I now have an ashcroft LT77s and it is just fine, gear changes are nice, half the price of the stubby R380 (which wasnt readily available when i changed my box) and was a direct replacement for the old LT77. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted August 2, 2010 Share Posted August 2, 2010 i would (and will went need to) replace the LT77 with a good recon one the axtra 600quid for the stubby R380 is a big jump and if you need a transfer box it's a BIG price jump so LT77 + T B Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 3, 2010 Share Posted August 3, 2010 The R380 is nicer, but it depends if it's nicer to the tune of buying a new one and/or moving the engine. I mean it doesn't bring car-like changes to the defender, 2nd still crunches when it's cold and is only a bit stronger. Personally, I'd rebuild both boxes, or rebuild other ones and swap them, to minimise your time off the road. Quote Link to comment Share on other sites More sharing options...
