DiscoHere Posted August 23, 2010 Share Posted August 23, 2010 Help! How do I get them off? They keep turning and I have nothhing to grip. Do I need to cut them off and if so is there an easy way of so doing? Hugh Quote Link to comment Share on other sites More sharing options...
MrKev Posted August 23, 2010 Share Posted August 23, 2010 Stilsons round the shiny bit should do it. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted August 23, 2010 Share Posted August 23, 2010 Yep, same as what he said Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 23, 2010 Share Posted August 23, 2010 Or if it doesn't, reassemble a hacksaw through the mount and set to it, takes about 5 mins per side Quote Link to comment Share on other sites More sharing options...
nick w Posted August 23, 2010 Share Posted August 23, 2010 or the heath robinson route of stabbing them with a screwdriver if stilsons arnt avaliable Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted August 23, 2010 Author Share Posted August 23, 2010 Thanks all i will try tomorrow and if I have any skin left on my knuckles i will let you know how i did Hugh Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted August 23, 2010 Share Posted August 23, 2010 Thanks all i will try tomorrow and if I have any skin left on my knuckles i will let you know how i did Hugh yep stilsons do it & wear some gloves its puffy & will save your skin good luck with them john Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted August 24, 2010 Author Share Posted August 24, 2010 Stilsons or vice grips were no use at all as the original nuts uses were nylon lock nuts. Having rung the top off both shocks i gave up on them. The answer i found in heat. I put a blowlamp on them until the nylon melted and to some extent acted as a lubricant. No problem to remove them using that method. So now i have added the blow lamp to my tool kit of large spanners and lots of hammers for working on Land Rovers. Hugh Quote Link to comment Share on other sites More sharing options...
