need4speed Posted October 4, 2010 Share Posted October 4, 2010 Looking for the part number for the self adhesive strips that go between the van sides and the main cappings. Also, from the factory the defender has self adhesive strips between the main cappings and the tub itself - hence why they can be tricky to remove. Is it necessary to refit these strips when fitting new cappings, or will i get away with just rivitting the cappings on? If i should renew them i need the part number for these too... Cheers Phil Quote Link to comment Share on other sites More sharing options...
western Posted October 4, 2010 Share Posted October 4, 2010 have a look through 110 parts book Body & Chassis Section or you could just use a good bead of Sikaflex or similar sealant. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 5, 2010 Share Posted October 5, 2010 I *heart* hatch-seal tape from the chandlers - very good closed-cell neoprene foam with a sticky-as-hell adhesive backing, available in various widths & thicknesses, lots of uses round a Landy. Quote Link to comment Share on other sites More sharing options...
need4speed Posted October 5, 2010 Author Share Posted October 5, 2010 I'll prob go along with what you use fridge, as the LR seals are £eek each... Cheers both of you Phil Quote Link to comment Share on other sites More sharing options...
