Fitting Late-Model Doors
ajh
When fitting the new pressed steel doors the door seal is on the door, but does not go the full length of the bottom of the door. What other seals are needed to complete the seal, right now I can see through about an inch in each corner of the door bottoms, which allows quite a bit of air in while moving.
Thanks, that doesn't seem very inspired, I also ended up with a spare set of P seals about 25cm long, any idea where those go? They could be strays picked up at the paint shop as well.
